Old 06-16-2005, 01:06 PM   #1
OttawaSTi
Member#: 64301
2004 STi
Default Installing HID level switch - which firewall hole?
I am in the middle of installing a set of HID's and the level switch in my Canadian STi... but I am not sure which hole in the firewall I am supposed to use. It's very toight back there and can't see much... so if someone has a picture they could post to show the proper plug/hole to use that'd be great! Or a good description works too!
Thanks in advance! I tried searching... but couldn't find anything this specific.
OttawaSTi is offline   Reply With Quote
Old 06-16-2005, 01:13 PM   #2
OttawaSTi
Member#: 64301
2004 STi
I know there is one somewhere behind the pedals... and supposed to be another one on the passenger side... but just looking to see if anyone has any pics of them.
Passenger one sounds easier to use - but not sure if the wire harness for the HIDs will reach that way.
Old 06-16-2005, 01:21 PM   #3
OttawaSTi
Member#: 64301
2004 STi
Well gonna try this one...
Old 06-16-2005, 02:03 PM   #4
wagons_ho!
Member#: 16574
From the engine compartment, under the intercooler by the drivers side of the firewall, there's a flat plug maybe 30mm 1.25" in diameter. Its position is above the gas pedal. Remember, I've only installed this harness in a TS - there's no IC. Some put a boost gauge through this plug.
That's the ideal place - out of the way.
From the picture you refered to, it would be higher up and towards the centerline of the car from the plug in that picture.
wagons_ho! is offline   Reply With Quote
Old 06-16-2005, 02:08 PM   #5
OttawaSTi
Member#: 64301
2004 STi
Cool thanks! Damn I/C in the way!
Old 06-16-2005, 02:25 PM   #6
wagons_ho!
Member#: 16574
FMIC or a TS makes it easy 8))
Old 06-16-2005, 06:45 PM   #7
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
I got anal (shocker) and wanted mine to be factory- so I routed mine through the fender- which of course required me to pull it off. Pretty easy tho. I made my levelling harness and routed it all in about 3 hours. Quality certainly surpasses "just get it done" in my book anyday
MK19_ is offline   Reply With Quote
JBP trunk lid-holes from sti wing/edm hid level switch wrxty Exterior/Styling 3 05-27-2008 03:59 PM
Installing hid leveler switch mathetes Electrical & Lighting 4 08-29-2007 04:58 PM
JDM HID leveler switch V REX Private 'Wanted' Classifieds 3 10-06-2003 04:54 AM
JDM HID leveler switch JoeJohnson Private 'Wanted' Classifieds 1 09-30-2003 10:07 PM
Were I can Find or Buy a HID Leveling switch and harness? thunderay Electrical & Lighting 1 09-03-2003 01:18 PM
