Old 06-16-2005, 09:29 PM   #1
lag
Member#: 34631
to live in fear
Default BD JDM headlight swap.
Just got finished with the swap. I got the headlights and side marker lights from a fellow forum member, Huffer. Haven't quite figured out how to get the high-beams on properly. I'm sure it's been discussed but I can't find the thread, so if some one can provide the link.
The easiest way for me to post up the before and after pics is to cross link to another forum...
http://www.rx7club.com/showthread.ph...75#post4463375
Those of you familar with the Rx7club know they can be "unique" so don't pay to much mind to 'em.
lag is offline   Reply With Quote
Old 06-16-2005, 09:36 PM   #2
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Thumbs up
I cant tell much from the pics but you get an "a" for effort.
ss
subysouth is offline   Reply With Quote
Old 06-16-2005, 10:56 PM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Looks good… I just finished wiring my projectors up as well (which I also got from another member) and found my stock 98 BD wiring to be completely different then some of the diagrams floating around here. I ended up rewiring them 3 times before getting it right. Since yours is a 98’ as well, I’d be happy to help if you need it.
PS: With my stock wiring, the solid RED is high-beam…
xcntrk75 is offline   Reply With Quote
Old 06-17-2005, 03:07 AM   #4
norabder
Member#: 40530
2008 Legacy
Quartz Silver Metallic
I got my lights in finally as well. Everybody's got'em or got to have'em
There she is at the "WBM" wicked big subaru meet in MA
Some great cars and people. BACK To the headlight, I got a wiring diagram for the lights I just need to scan it. I'll try to get it soon don't have acess to a scanner right at the moment.
norabder is offline   Reply With Quote
Old 06-17-2005, 09:10 AM   #5
lag
Member#: 34631
to live in fear
Yepper, I need wiring help. I'm usually good at that type of thing, but as you can see from the pics it was about going on 9pm so I didn't really have a lot to work with///I didn't start until about 8 so that's my fault.
Old 06-17-2005, 10:20 AM   #6
masube
Member#: 59226
2005 Sti
Wow nice pic norabder.
masube is offline   Reply With Quote
Old 06-17-2005, 10:22 AM   #7
crazex
Member#: 27677
2005 STI
Crystal Gray
Here is the wiring harness diagram. Subaru switches grounds, not power.
crazex is offline   Reply With Quote
Old 06-17-2005, 11:47 AM   #8
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
See that’s the diagram I was referencing which didn’t match my existing 98 BD wiring whatsoever. Lag I imagine your wiring is the same as mine. I have the following wires on the stock BD plugs:
LH:
Red - HIGH BEAM
Red/Blue - POWER (MB-6)
Yellow/Blue - LOW BEAM
RH:
Red - HIGH BEAM
Black/Yellow - POWER (MB-8)
Just correspond these to the JDM lights. Keep in mind that the running lights can be wiring on either low or high beam, if you want them at all.
Old 06-17-2005, 01:42 PM   #9
crazex
Member#: 27677
2005 STI
Crystal Gray
The colors of the wires may be different, but they should function the same way. Basically, make sure that when you are wiring them you make it so the ground switches when you change beams. The power stays constant to each bulb.
-Jon-
Old 06-19-2005, 02:09 AM   #10
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
norabder,
you need a motor swap and painted trim and we can be brothers.
subiekid is offline   Reply With Quote
Old 06-19-2005, 02:37 AM   #11
hklaine
Member#: 55320
Originally Posted by xcntrk75
LH:
Red - HIGH BEAM
RH:
Red - HIGH BEAM
I found this text document kicking around. Maybe test it with your multimeter and see if it makes sense?
LH:
Low: B/Y+ Y/B-
High: B/Y+ R-
RH:
Low: R/B+ Y/B-
High: R/B+ R-
It was in a folder of pics I took when I installed the relays and new wiring to my high-wattage headlights which are working so as long as it was my last version it should be correct (my headlights work). Hope it helps and/or is correct.
-Heikki
hklaine is offline   Reply With Quote
Old 06-20-2005, 06:31 PM   #12
lag
Member#: 34631
to live in fear
Thanks people, I should have some time this week to finalize this.
Thanks again, --
Old 06-21-2005, 06:36 AM   #13
SubaruGenki
Member#: 65058
02 Eagle Summit
TSi
You have a rotary too?
SubaruGenki is offline   Reply With Quote
Old 06-21-2005, 04:12 PM   #14
etam
Member#: 439
www
This is for pre-98 H4 headlights.. starting from 98, 9007 bulbs are used.. you probably need to take out your voltmeter to see which one is switch ground.. when switching between hi and low beam...
oh.. that's a ugly hand-drawn diagram.. I wonder who did that
etam is offline   Reply With Quote
Old 06-22-2005, 12:57 PM   #15
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Looking good lag - hope you get the wiring sorted out.
Huffer is offline   Reply With Quote
Old 09-30-2005, 10:46 PM   #16
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I won a set on Ebay a couple days ago, should have them next week. This will certainly come in handy.
Pat
Old 09-30-2005, 10:55 PM   #17
Gator GT
Member#: 37190
07 specB - 6spds,
4 tips, 3 LSDs, stg 2!!!
mmm, just got me a bonus! time to look for a nice set of these!!
GGT
Gator GT is offline   Reply With Quote
Old 10-16-2005, 05:43 AM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Stupid question, I'm sure, but... what bulb type(s) do I need for the projector and non-projector? I'll probably try to figure out the install tomorrow, but it would be nice to put fresh bulbs in while I'm at it.
Pat
Old 10-16-2005, 09:36 AM   #19
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Projector is a H1 and High Beam is a H3
wrx_driver_2002 is offline   Reply With Quote
Old 10-16-2005, 12:57 PM   #20
Cajual
Member#: 12900
1997 Legacy GT-Turbo
Quick Silver Metallic
And there is a driving lamp as well... it takes a 168 Accessory wedge bulb.
Cajual is offline   Reply With Quote
Old 10-19-2005, 03:22 AM   #21
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
OK, I'm officially confused. Just to be sure I had things straight, I went out to the car with the multimeter to check some voltages. As I describe this, I'm holding the wiring harness with the open end of the plug facing me. With the lights on low beam, I get GND on the top (horizontal) contact, and 12V on both the left and right (vertical) contacts. When I switch over to high beams, I get GND on the top and left contacts, and 12V on the right contact. Based on people saying Subaru switches grounds, I expected that when on low beam the left terminal would be open circuited and the top terminal would be grounded, and when on high beam the top terminal would be open and the left terminal would be grounded. What am I missing here?
Oh, and just to make this interesting (nothing ever goes easy for me when it comes to car projects), the driver side plug is so corroded that the power contact fell apart while trying to clean it. And I have a heavy duty power harness with relays that are switched off that plug, so now I have no headlights until I fix that. (Well, I could just plug the factory harness onto the passenger side headlight, but I'm not one to drive around one-eyed!)
Pat
Old 10-19-2005, 05:46 PM   #22
T-Leg
Member#: 94758
1991 Sport Sedan
Is it hard, or even possible, to aim these correctly? Japan being RHD and all. I know the earlier JDM lights, BC-BF, can't be aimed to be used on LHD cars. I don't know if the problem is the lense or the reflector.
T-Leg is offline   Reply With Quote
Old 10-29-2005, 06:04 AM   #23
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Any help here? I really don't understand how the voltage measurements I've taken correspond to the "Subaru switches grounds" thing. I'm going to remove the 4-prong connectors on the JDM lights and wire it to a "normal" 3-prong plug so it'll be plug-and-play with the stock wiring harness. In order to do that, though, I want to be sure I understand how power is supplied, and right now what I'm measuring doesn't seem to match what I've read is supposed to be the case.
Thanks,
Pat
Old 10-29-2005, 09:01 AM   #24
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
That sounds like a great approach. Remember the JDM lights have the extra wire (4-prong) for the “driving light” on the outside of the projector. You can combine this accent light with low or high-beam, or simply leave it disconnected. I chose low beam as that’s how the 05’ US projector setup is, but may dissconnect it all together to get the single projector look.
Also, I would leave your connections accessible which you make the first time around with the stock plugs on the JDM lights. This way you can go back and swap some wires around if you don’t get it the first time. Took me about 3 times to get it right. It’s pretty easy but with a lot of trial and error. First time I had “low” on one side with “high” on the other which would reverse when the switch was moved from low-to-high, so it takes some messing with…
Old 10-30-2005, 01:09 AM   #25
etam
Member#: 439
www
Pat
Pat, your description is correct but don't know why your measurement is NOT.
There are 2 filaments in H4 bulb.. I *think* (anyone can confirm that? ) the way H4 bulb works is switching one on and one off when in either high or low beam.
low beam:
low beam circuit from right connector to top: +ve to -ve; light on
equal potential (same +ve) from right to left connector (high beam circuit); light off
high beam:
right connector to left connector: +ve to -ve; light on
equal potential (same +ve) from right to top (low beam circuit); light off
Your measurement suggests to me that only 1 filament is on when low beam; 2 filaments are on when high beam.
When I did that diagram, I don't remember if I follow the Subaru ground switching scheme. That was my first version to wire it up.. shortly after that.. I made a home-made relay harness to power the bulbs directly from battery.. and then I modified it more when I put in HID.
With high performance wiring harness.. you should be able to wire it up from one H4 connector.. harness should use some relay to run off battery directly?
Make sense?
FS: $FREE.99 - JDM driver side BD/BG headlight, broken Patrick Olsen Legacy Specific Parts 4 06-14-2008 05:56 PM
JDM or EDM BD/BG Headlights??? Need some opinions (with PICS) Mikeye Legacy Forum 35 04-22-2008 11:01 PM
Anyone need just a right/passenger side JDM BD/BG headlight? Patrick Olsen Legacy Forum 13 02-19-2006 09:35 AM
WTB: BG/BD JDM Projector Headlights OEM kotani Private 'Wanted' Classifieds 4 08-31-2004 12:52 PM
any electrical people wanna help with a JDM headlight swap? monovich Southern California Impreza Club Forum -- SCIC 10 07-02-2002 12:24 PM
