Old 06-17-2005, 04:17 AM   #1
smkm1023
Member#: 44950
1999 Passat GLS 1.8t
Default 02 WRX Pressure Plate Bolts
Does anyone know where I can find the torque specs for this? I searched and couldn't find anything. Thanks in advance.
smkm1023 is offline   Reply With Quote
Old 06-17-2005, 09:30 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The factory manual says like 12 ft/lbs.....but that seems pretty low IMO
Legacy777 is offline   Reply With Quote
Old 06-17-2005, 03:13 PM   #3
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Correct! But my torq-wrench only goes down to 20Lbs so that's what I set them at WITH some lock-tight too!(just in case).
wrx plus is offline   Reply With Quote
WTB 02 wrx pressure plate bolts. scOOtNsOOby Private 'Wanted' Classifieds 0 10-04-2009 09:29 PM
FS:Used 02 WRX Pressure Plate and Disk OEM exedy winston0064 Drivetrain 3 01-09-2008 10:00 PM
NYC: 02 WRX Pressure Plate & Clutch Fork Gordata Drivetrain 0 08-07-2006 12:21 PM
WTB: Pressure Plate Bolts ASAP. Soon2Bgreat Tri-State Area Forum 8 09-06-2005 04:34 PM
rear main seal replacement?+ flywheel and pressure plate bolt torque? Haase14 Transmission (AT/MT) & Driveline 7 01-17-2003 10:42 AM
