Old 06-17-2005, 12:02 PM   #1
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
Default 8cm stock location turbo's and turbo inlet pipe size?
Would a stock location 8cm turbo require a 3in inlet pipe or can I use the 2.25? size.....basically old perrin style or require the new style?
Matt
mpower22 is offline   Reply With Quote
Old 06-17-2005, 12:16 PM   #2
pux888
Member#: 8356
02 STi swap
12 WRX limited
does not require a 3' inlet. it gonna depend on what you buy.
pux888 is offline   Reply With Quote
Old 06-17-2005, 12:17 PM   #3
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
In a nutshell to answer your question, you will need to figure out what compressor housing will be used on your application and go from there as it has nothing to do with the 8cm^2 turbine housing (rear housing).
Rick
ami2fst4u is offline   Reply With Quote
Old 06-17-2005, 12:28 PM   #4
mpower22
Member#: 58352
04 20G STI(SOLD)
basically I'm going to be going with a fatboy internally gated sz-55...in the next few weeks I think Jerry will be making some with a 8cm inlet....
Matt
Old 06-17-2005, 12:45 PM   #5
ami2fst4u
Member#: 40638
'04 PSM STi
Again it's not an 8cm inlet.... the 8cm^2 referes to the turbine housing which is the rear housing on a turbo where the downpipe bolts up to. Furthermore, for your own reference the "Fatboy" wheel refers to the turbine wheel which is inside the turbine housing (8cm^2).
Back on topic, the inlet attaches to the compressor housing in which I believe Jerry uses an TD06 20G compressor housing on the SZ55. With that said, the "normal" style Perrin turbo inlet pipe (2.25") should fit without a problem.
Rick
Old 06-17-2005, 12:48 PM   #6
mpower22
Member#: 58352
04 20G STI(SOLD)
Rick
Sorry thats what I meant but was confused when people were saying 8cm and inlet.....kewl beanies....tanks guys...so the 8cm housing just adds a little topend?
Perrin afta-maf and turbo inlet pipe. Did I waste my money? kylelikewhoa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-07-2007 01:28 PM
WTB crank pulley intercooler pipe and turbo inlet pipe yellowsooby Private 'Wanted' Classifieds 3 04-16-2006 06:35 PM
IL: Brand New OEM Stock WRX or STi Turbo Inlet Pipe / Hose Red Rexx Mid West Subaru Owners Club Forum -- MWSOC 0 08-09-2005 02:10 PM
IL: Brand New OEM Stock WRX or STi Turbo Inlet Pipe / Hose Red Rexx Private 'For Sale' Classifieds 0 08-09-2005 02:10 PM
needed: looking for stock WRX turbo's and OEM up-pipes petrol Texas Impreza Club Forum -- TXIC 27 06-15-2004 11:53 AM
