Old 06-17-2005, 09:02 PM   #1
zmaster
Member#: 88995
11 WRX Premium
True Subaru color WRB
Question Sway Bars for 05 2.5rs
Hey guys,
I was on here the other day and i was wondering if a stock wrx sway bar...i think 20mm can fit on a 05 rs?? and if so are there instructions out here..cos i called up a auto place to find out how much it would cost for installing one ...and they are quoting me something like $ 250
zmaster is offline   Reply With Quote
Old 06-17-2005, 09:11 PM   #2
Handsdown
Member#: 29355
yes, it will.
ask the suspension forum, they'll tell you what to do.
you just have to unbolt the stock one and put the new one in... it's CAKE and takes 20 minutes.
you can probably find a used WRX bar from someone who's upgraded to aftermarket. they often go for less than 50 bucks.
DON'T pay ANYONE 250 for a swaybar + install, you can get an adjustable aftermarket one that will improve your handling for ~ $200 and installing can be done with simple floor jacks or ramps (i did mine on steel wedge ramps) and it took me 30 minutes. there are two brackets with bushings that hold the bar(be sure to get the 20mm bushings as well) and you also must bolt the ends of the bar to the endlinks. it's nearly self explanitory once you're looking at it.
search the suspension forum, there are lots of threads about sway bars.
Handsdown is offline   Reply With Quote
Old 06-17-2005, 09:16 PM   #3
iownaspec
Member#: 34154
1/2 jew crew
umm i installed my 02 wrx rear sway on my 05 obs in about 20 mintues. its not very hard. and while you are down there with the rear sway get metal endlinks.
iownaspec is offline   Reply With Quote
Old 06-18-2005, 12:02 AM   #4
RodimusPrime
Member#: 82118
2005 GD6 2.5RS
Crystal Gray Metallic
I installed an 05 WRX rear sway bar (17mm) on my 05RS to replace the stock 13mm one. The install was very simple and took about 20 minutes. Handling was vastly improved.
If you don't know much about how to handle a car with more oversteer, maybe step up to the 17mm first. You will notice that the back end will start to come around much more easily with a stiffer rear sway. I figured since the 17mm came stock on the WRX, it'd be a safe bet.
Just be safe whichever you get and enjoy it!
RodimusPrime is offline   Reply With Quote
Old 06-18-2005, 12:07 AM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
20mm would really be best for neutral handling
(your front bar is 19mm)
21mm if you like a happy tail end
some examples *click*
i have 19mm front and 21mm rear - love it
Jamie
www.subiegal.com
Old 06-18-2005, 12:26 AM   #6
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
Jamie
www.subiegal.com
i have the third one (20mm) and i love it. installation is a breeze. i did a write up on it in the car parts review section. if you care enough you can search for it.
svek is offline   Reply With Quote
05 sti front sway bar on 05 2.5rs? oatmealman Newbies & FAQs 3 11-02-2007 10:30 AM
OEM 20 mm rear sway bar for WRX/2.5RS/2.5i fung87 Suspension/Brakes/Handling 3 06-29-2007 03:18 PM
05 WRX Rear Sway Bar on 05 2.5RS shortysman999 Brakes, Steering & Suspension 1 10-28-2005 05:07 AM
wtb: aftermarket front sway bar w/bushings. 2.5rs or wrx wagon Keith Private 'Wanted' Classifieds 1 02-08-2005 08:32 AM
WRX Sway bar installed on 2.5RS - Review mtbhadfield Brakes, Steering & Suspension 4 11-09-2002 03:03 PM
