Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-18-2005, 03:46 AM   #1
EuroSTI
Member#: 89122
Question Hydra vacuum question :)
Hi there,
I have just noticed that my off throttle vacumm on my boost gauge (around 4500-2500 rpm, when the throttle is shut) has raised after I fitted the Hydra. Before it was around -550 bar (app 400 mmHg) now it is around -0.9 bar (app 650mmHg).. Does anyone have an idea on this?? Or is there a cure for that )
EuroSTI is offline   Reply With Quote
Old 06-18-2005, 10:38 AM   #2
Element Tuning
Member#: 54918
It sounds like you may have had a leak at your boost gauge/fitting. It's normal to see 610 - 650 mm/hg under heavy compression braking. My gauge also read low and I found that the one way valve at the front of the manifold was damaged.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Vacuum Question! 08SubieWRX Newbies & FAQs 16 01-03-2009 09:49 AM
Hydra Help!! Please :) Pi7467mp Other Engine Management 7 11-10-2004 10:34 PM
Vacuum Question benjaminetanyahoo Normally Aspirated with bolt-on Forced Induction Powertrain 6 05-28-2004 05:48 PM
Vacuum questions? ImprezedRS Normally Aspirated Powertrain 9 01-23-2003 02:24 AM
Brake Torquing Launches/Vacuuming Question RobPA Transmission (AT/MT) & Driveline 17 05-06-2002 07:06 PM
Message Board Statistics All times are GMT -4. The time now is 08:45 PM.
