Old 06-18-2005, 07:52 AM   #1
Keith
Member#: 191
2012 J train
Brown
Default ghetto logging. take a look at my Tari log, need help
Well, since everything in my doesn't work (including the defog switch) I can't log my runs using the tari software. The orginal version though, did have a min/max option that allows me to "log" my car a bit.
I took some screen shots and was wondering if anyone could tell anything from this.
Car: 93l with 02 USDM wrx engine and 03 ecu.
I have 12309349028490832094 cels but can't pull them as of yet (any good free software?)
this run, I wasn't able to go over 5k rpms because *sometimes* (most of the time) I can't get it over 5k rpms as it bucks like crazy (feels like fuel cut or something)
anyways, take a look
mods:
Samco intercooler hoses
lightend flywheel
3" bpm tbe with high flow cat
hks ssq bov
walbro fuel pump
aftermarket up-pipe (no cat)
jdm tyte Red fender that is rusted
Keith is offline   Reply With Quote
Old 06-18-2005, 10:20 AM   #2
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
why doensn't yoyu defogger switch work? do you have it selected in the Digital input section?
Quack is offline   Reply With Quote
Old 06-18-2005, 01:18 PM   #3
timmah
Member#: 54203
2011 WRX
because nothing on his car works like it should, its a swap....
timmah is offline   Reply With Quote
Old 06-18-2005, 01:33 PM   #4
Quack
Member#: 57264
ahhh...gotcha...missed that part
Old 06-18-2005, 04:46 PM   #5
willguidry
Member#: 16388
Drive it into a shallow creek bed.
That should fix all your issues.
willguidry is offline   Reply With Quote
Old 06-20-2005, 12:53 AM   #6
Keith
Member#: 191
2012 J train
Brown
tried that, just made it worse (thanks buddy)
Old 06-20-2005, 06:56 AM   #7
Abe Froman
Member#: 22309
04 STI
05 LGT Wagon
Thumbs up
I'm no expert but I'll give it a shot.
First off your advance multiplier is down so the car has seen some detonation. 16 is the max and you're only hitting 8. Run better gas or drop the boost until you sort out the issue.
You're running a little over 14.3psi so that looks fine.
Fuel pump duty cycle shows only the lower setting, it's not switching to the higher duty cycle. At 14psi I think it should be switching to the higher mode.
Your timing is pretty low, again probably from some det. 11 degree is low even for peak torque for a WRX engine.
That should get you started.
Abe Froman is offline   Reply With Quote
Old 06-20-2005, 08:31 AM   #8
Keith
Member#: 191
2012 J train
Brown
thanks
well, i can't turn the boost down as the ecu is stock..no mods done to the boost (no mbc or ebc). ahhaha
As for detonation, I don't know how/why I'm hitting it. The gas I use is fine (highest octane).
there has to be an wiring issue. Any idea why the fuel pump wou;dn't switch to the higher duty cycle? (remember, this is a swap from a 93L to a 02 wrx)
thanks for the ideas
Old 06-21-2005, 07:14 AM   #9
Abe Froman
Member#: 22309
04 STI
05 LGT Wagon
Originally Posted by Keith
thanks
What is the octane? 91 or 93? If 91 is the best you can do then the car it probably running fine, it encountered knock and pulled back your advance. It might not be knocking right now it's just running lower advance, it's not a problem really.
I'm not sure about the fuel pump, but I think at a certain boost pressure it should switch to the higher duty cycle, not sure what pressure that is to be honest, do some searching on fuel pump duty cycle and you might find it.
HTH
Take a look at my first logs? silence2-38554 Open Source Reflashes 8 08-12-2009 06:39 PM
Please help take a look at my logs... spitfirezip100 Engine Management & Tuning 22 04-27-2007 03:12 AM
take a look at my stg2 log! Dizzuque Commercial ECU Reflashes 2 02-04-2007 04:12 PM
Take a look at my VF22 UTEC log? 03WRXMA Engine Management & Tuning 12 07-02-2004 05:51 PM
could someone take a quick look at my UTEC log from a pull? 03WRXMA Engine Management & Tuning 23 05-21-2004 03:57 PM
