Old 06-18-2005, 11:48 AM   #1
turbosporttsi
Member#: 85848
1998 M3
Default another utec question
i got a used utec with 2 maps already loaded, ok? its off the same year car with almost identical mods,(just brand difference) will i be safe to use that map for a while, until i can get to a dyno or learn to do it myself? i know every car is different, but ours should be close enough to not pose a problem, right?
any advice/opinions welcome. thanks again.
turbosporttsi is offline   Reply With Quote
Old 06-18-2005, 04:14 PM   #2
TurbojonLS
Member#: 38772
2 Cars, No Bling
It depends. If the changes made to the tune weren't major (a few * of timing, a little fuel changes), you're probably ok. If they had an extreme custom tune done, you might be ok, you might not be. Regardless, I'd probably re-map the boost just to make sure its working how you like.
TurbojonLS is offline   Reply With Quote
Old 06-19-2005, 03:23 AM   #3
turbosporttsi
Member#: 85848
1998 M3
cool, thats what i thought. will do. thanks alot.
Another Utec/Idle/Cams question TyranosaurusWRX UTEC 7 06-19-2009 02:09 PM
Another, yes... another turbo question... o_O"... Liam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 05-20-2007 01:06 AM
utec question changing to MBC from utec boost trbowrx Engine Management & Tuning 8 06-28-2005 08:15 AM
Another UTEC map question bhkim126 Engine Management & Tuning 3 11-20-2003 03:54 PM
Another UTEC question DiMensionX Engine Management & Tuning 26 10-01-2002 04:03 AM
