Old 06-18-2005, 03:18 PM   #1
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
Default this might be dumb: but would an STi intake manifold fit on an NA 2.5RS?
I've seen a lot of people parting out their sti intake manifolds, im wondering if they would fit on my 2.5RS, we both have 2.5 liters but one is turbo one is not.
would it fit with out a lot of custom modification?
I guess the manifold would increase some more power and its really bling!
thanks
Impreza2003 is offline   Reply With Quote
Old 06-18-2005, 03:18 PM   #2
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
BTW my RS is an 03
Old 06-18-2005, 03:25 PM   #3
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
My guess? Fit, no. Power, unlikely. Bling, definitely, but at what cost? Paint your stocker red and call it a day, methinks.
LetItSnow is offline   Reply With Quote
Old 06-18-2005, 04:17 PM   #4
HolyCrikey
Member#: 66776
2005 Mazda3 Hatch
Titanium Grey Metallic
I don't believe it'd fit. Yea, just get your's powder-coated. Even if it'd fit, it would indeed be a waste of money without any substantial power gains.
HolyCrikey is offline   Reply With Quote
Old 06-20-2005, 07:47 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Well,
It depends on what year. I have an STi v6 (MY00) intake manifold that will eventually make it's way onto my car. From '99 on, the Ej25's and Ej20's got the same bolt pattern. And the v6 one I have has larger runners that are going to flow better. But I won't be doing this until I have finished my 250+hp engine.
And one thing to be aware of with this is that you will need to switch the throttle cable over to the other side of the manifold, and find a place to put your coil pack...
And lastly, no you cannot use a USDM v8 EJ257 intake manifold. It is not the bolt pattern that is an issue. It is the throttle body. Your throttle body will not fit, and you cannot use the STi one because of the drive by wire...
Old 06-21-2005, 01:20 AM   #6
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
even if you could fit it the diameter of the piping of the STi intake manifold is designed for a turbocharged vehicle and as i read somewhere ont his forum you will lose power on an N/A ej25 unless you got some serious mods and are pulling out 250+ hp
Caplin 2.5 is offline   Reply With Quote
Old 06-21-2005, 01:56 AM   #7
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
interesting, thanks everyone
there goes another cool modd trampled down by the EJ25 engine!
im getting an STi next
Old 06-21-2005, 04:21 PM   #8
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
I feel you brother
CitySubie is offline   Reply With Quote
Old 06-21-2005, 05:44 PM   #9
LetItSnow
Member#: 38222
'10 &'12 Foresters
If you're any bit interested, look into intake manifold design. The runners are the length they are for a reason - it has to do with air pulses bouncing up and down the runners at a certain rate, and pushing or pulling other ones past the valves. Technically, every car has "ram air".
Old 06-21-2005, 07:07 PM   #10
Caplin 2.5
Member#: 71203
2005 2.5rs
As I've found out by first hand experience making things specifically for your car is the best way to make power. First thing I would do is find out what the diameter of the stock STi manifold is, then find out the diameter of the stock RS manifold, then look up an aftermarket STi manifold copy the design with the RS diameter. You might be able to make your own custom intake manifold.
Old 06-21-2005, 11:47 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Not sure where you read that, but I beg to differ. Unless the STi intake manifold has more restrictive runners than the N/A 2.5L intake manifold (highly unlikely), there's no way you would lose power with an STI manifold. The power peak and power band may shift, but you certainly wouldn't lose power.
...then look up an aftermarket STi manifold...
Can't say I've ever seen an aftermarket intake manifold for any of the various Subie engines. Is there something I've missed?
Pat Olsen
'97 Legacy 2.5GT sedan
Old 06-22-2005, 02:28 AM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
Magnus Motorsports makes an aftermarket manifold.....Maybe you missed it? :P
Their design may lend itself well to the NA crowd too (if it weren't so dam expensive)...
Jay Storm
Old 06-22-2005, 07:13 AM   #13
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Instead of using an STi intake manifold on our cars (which we can't) why don't we consider using the new intake manifolds on the 05 RS. From what I know they flow better than any of the other previous manifolds on RS's. If you look at them you can see that the runners are larger, and will obviously flow better. I think if you want to flow more air looking at this option is a very good idea. Then all you have to do is see if you can find some AVCS heads and an ECU to run them and your set. From another post I think it would be possible to find heads with AVCS for our cars. Think of all the possibilities.
X4 SRT is offline   Reply With Quote
Old 06-22-2005, 07:15 AM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Thanks, Jay, I had missed that. Wowzers!! $1200 for an intake manifold!!
Sure looks purty, though.
Old 06-22-2005, 11:56 AM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
Why do people always treat variable valve timing as some sort of magic pill? It is not a performance feature, it is an emissions feature. For the cost of getting AVCS to work, you can get a set of cams properly ground for real performance. Take the path of least resistence. Do you guys realize that the Rigolis have started using the SOHC EJ25 heads for their drag cars instead of the v8 STi heads they had been using before?
Old 06-22-2005, 12:58 PM   #16
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Welllll, it's not just an emissions feature. From what I've gathered with all of these variable valve timing and lift systems (Variocam, VVT, VVTi, VTEC, etc etc) one of the biggest benefits is a broadened power band. So, I guess I agree with you in that peak power won't change much, if at all, but the good ol' "area under the curve" can be substantially better.
Pat
PS - empty some space in your PMs, compadre, so I can respond to your response.
Will an 04 STI Intake Manifold fit 03 wrx EJ205? simon930 Built Motor Discussion 7 12-03-2009 11:23 PM
Will an sti exhaust manifold fit the 2.0 Wrx? plus plus plus Newbies & FAQs 5 07-25-2007 08:17 PM
Would 16x8 1/2 fit on a 99 2.5rs with out spacer? 99WRXEJ20 Tire & Wheel 3 04-05-2004 12:22 PM
This might be blasphemy but... mykrrrr STi Forum Archive 44 01-13-2003 06:26 PM
