Old 06-18-2005, 07:35 PM   #1
gdweible
Member#: 89506
2005 Legacy 2.5 GT
Garnet red
Question 2.5 GT horns
I want to replace the anemic factory horns on my 2005 2.5 GT Wagon.
I know they are there. I can hear them.
Where are they?
I have looked all over the engine compartment and they are doing an excellent job of hiding. I expect that someone will tell me that I have to remove the headlight modules because the horns are behind/below them. A task I would like to avoid if possible.
If I can't get to the horns, is there somewhere I can get to the wires to the horns?
Oh yeah, and related. Anyone know where I can get a manual for the car? The very expensive factory shop manuals are a bit out of range.
gdweible is offline   Reply With Quote
Old 06-18-2005, 08:03 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I'd think they're behind the grill as on the Imprezas although I haven't looked closely enough at an 05 Legacy to confirm.
As for manuals, you can go to the Subaru tech website and get the $34.95 subscription for 72 hours to download the manuals in electronic form. It's tedious but a great bargain compared to the cost of the print version.
http://techinfo.subaru.com/html/index.jsp
Old 06-19-2005, 10:00 AM   #3
gdweible
Member#: 89506
2005 Legacy 2.5 GT
Garnet red
Thanks a lot for the tip on the electronic manuals.
The location of the horns was located in the "Communications System" section. ????????????
They are supposed to be behind the bumper and below the headlights on the right side. I have to check, but they might be accessed thru the wheel well 'mud guard'.
Old 06-20-2005, 02:16 PM   #4
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Wish I would have seen this thread earlier...
You have a PM about where to find the service manuals...
And the two best ways of gaining access to the horns are:
1) remove the airbox.
2) remove the clips in the fender liner and bend it out of the way.
crash is offline   Reply With Quote
Old 06-20-2005, 02:21 PM   #5
crash
Member#: 1440
05 LGT Wgn; 04 FXT
Oh, and by the way, there are two horns in there.
They each have one wire going to them, and they are grounded through the horn body where it mounts to the car.
This makes for a very easy solution if you'd like to use a relay to control your new horns.
I highly recommend the Hella Supertones (VERY LOUD, but VERY Directional really only good for honking at someone in front of you)
http://www.rallylights.com/hella/horns.asp
I have them mounted behind my grill on my Legacy, but I had to fab up some of my own brackets to make them fit.
I need to take the time to make a write up on LegacyGT.com
98 2.5 GT to 98/04 2.5 GT/STI UTCiv Legacy Forum 246 06-01-2011 10:29 PM
K&N Air Filter Impreza 2.5/WRX/STI 2008, Legacy/OB 2.5/GT/B 2005-08, Tribeca 2006-08 Longitude Engine/Power/Exhaust 2 09-04-2008 12:57 AM
Legacy 2.5 GT vs. Impreza 2.5 RS beantmt Newbies & FAQs 1 06-06-2007 04:05 PM
2.5 GT horns gdweible Legacy Forum 9 06-20-2005 08:30 PM
Any difference between a 97 2.5 gt and a 98 2.5 gt Polskino Legacy Forum 3 12-21-2003 07:51 PM
