Old 06-19-2005, 03:30 AM   #1
MMBOOST
Member#: 24140
02 Impreza WRX
http://www.logmapper.com
Default LogMapper 2.0 released, more goodies, easier to use, better config
LogMapper is a UTEC log processor. Given a raw UTEC (or UTEC + Tuner) log it can produce an overall view of how your tuning maps are performing. It does this by gathering all log entries that correspond to a particular UTEC map loadsite and for each loadsite it averages them together. Then, these averages are placed in a chart that is very similar to a UTEC map, a grid of RPM vs. load percentages. LogMapper is comprised of a "LogMap", a "TargetMap" and "Cell Source Windows". Each serves to provide a different view of your log data to help you meet your tuning goals. LogMapper currently is capable of automatically identifying and mapping UTEC logs for the Impreza WRX and Impreza WRX STi, with or without a TXS Tuner.
- Differences between LogMapper versions 1.x and 2.0:
* Addition of the "Cell Source Window", showing the data that makes up the LogMapper averages
* Inclusion of the old "Afr Targetor" into LogMapper as the "TargetMap"
* Capability to have your own AFR targets for the TargetMap
* Capability to specify your own TargetMap ("AfrTargetor") AFR delta thresholds for changing rich/lean cell colors.
* Built-in documentation
* Automatic log type detection - no more need to specify the log type
* Optional Configuration file to set a default font size and AFR targets filename
* More intelligent data processing to weed out unwanted logging anomolies that occur at specific events, such as flat-foot shifting, very quick throttle changes, etc.
* More stringent log reading to better identify corrupted data
* Capability to change the font within the map views
* A "tab" structure to the LogMapper interface for easier use of new features
Beta testers who have seen most of this already will hopefully be pleased to see the additions of the capability to change the AFR delta threshold and that lean/rich TargetMap cell backgrounds are now colored instead of just the delta numbers changing color.
You can download [LogMapper 2.0], see documentation and get a full introduction to the software at: http://www.LogMapper.com
MMBOOST is offline   Reply With Quote
Old 06-19-2005, 07:12 AM   #2
gadget951
Member#: 18419
WR Blue
Object not found!
The requested URL was not found on this server. If you entered the URL manually please check your spelling and try again.
If you think this is a server error, please contact the webmaster.
Error 404
I think you left out an "l" in your address for the logmapper20o.jar
Thanks for your effort I hope to try this out tonight when I get home from the track.
Scott
gadget951 is offline   Reply With Quote
Old 06-20-2005, 01:24 AM   #3
MMBOOST
Member#: 24140
02 Impreza WRX
Fixed. Thanks. All that work, just to shoot myself in the foot
Old 04-29-2006, 02:59 AM   #4
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
HOw accurate it is without a wideband?
gaby is offline   Reply With Quote
heads for 2.0 what cams and valves to use kennwrx Newbies & FAQs 6 04-24-2008 10:15 PM
Swapped 2.5 block useing 2.0 heads. Jumpy from 3k to 5krpm MY2ND04WRX Built Motor Discussion 29 06-01-2007 10:26 PM
Final LogMapper 2.0 beta w/ automatic log type detection MMBOOST Engine Management & Tuning 2 06-13-2005 10:26 AM
LogMapper 2.0 (beta) has arrived MMBOOST Engine Management & Tuning 12 06-05-2005 11:21 PM
