Old 06-19-2005, 11:31 AM   #1
avengermike
Member#: 88713
04 STi
Default oil coming out of boost controler
can someone tell me why oil is coming out of my boost control er please
avengermike is offline   Reply With Quote
Old 06-19-2005, 12:24 PM   #2
pux888
Member#: 8356
02 STi swap
12 WRX limited
woah....bump for someone to help you
pux888 is offline   Reply With Quote
Old 06-19-2005, 12:32 PM   #3
STiTuner
Member#: 5778
09 135i
Jet Black
that can't be good.....
STiTuner is offline   Reply With Quote
Old 06-19-2005, 12:34 PM   #4
avengermike
Member#: 88713
04 STi
thats what im thinking.... lol
Old 06-19-2005, 12:48 PM   #5
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Its oil blow by that is getting blown / sucked into the intake manfold. This is the reason top install a oil catch can. Stops the oil from getting back into your intake.
It is fairly normal for turbo cars that are driven hard or on the track.
WRX 2002 is offline   Reply With Quote
Old 06-19-2005, 01:03 PM   #6
avengermike
Member#: 88713
04 STi
cool thank u i did install a occ about two weeks ago and it has oil in it, so u dont think anything else could be wrong. new to these cars i sold my power stroke for this car, and my truck lived in oil. lol but then i saw spots all over the eng bay and my boost control had oil all over thought the turbo was dieing
Old 06-19-2005, 01:23 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....or ya blew it up already.
do a compression check.
Old 06-19-2005, 02:21 PM   #8
stott
Member#: 39558
2004 STi
yeah, if you have lots of oil, it probably is indicative of a problem. If you pull the turbo outlet hose, a quick look should tell you if your turbo is ok or not. After that go for a compression check.
How much boost are you running and what type of gas?
stott is offline   Reply With Quote
Old 06-19-2005, 03:02 PM   #9
attitude
Member#: 52043
04 sti
you installed a catch can, but oil is still getting by? are you sure you installed it correctly?
attitude is offline   Reply With Quote
Old 06-19-2005, 04:56 PM   #10
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
the standard catchcan install will stop maybe 50%..
DISCOPOPE is offline   Reply With Quote
Old 06-19-2005, 05:14 PM   #11
avengermike
Member#: 88713
04 STi
the car runs fine, but i have oils spots in the eng bay and the only thing that oil is coming from that i can tell is the boost controler, im running 1 bar which should be 14psi, and i only use 91 oct or better
trying to figure out why oil is coming out of this... Clin10 Normally Aspirated Powertrain 6 03-10-2010 04:35 AM
Oil coming out of exhaust and bov!! Venom911 Service & Maintenance 2 12-17-2009 07:37 PM
Hiccup coming out of boost into vacuum. biggreen96 Pre-2002 Factory Turbo Powertrain 2 01-31-2007 07:56 PM
Oil coming out of BOV? DarkKnight04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 12-01-2004 02:21 AM
Oil Coming Out of My Perrin Intake. SupersayianNeo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-19-2004 12:45 AM
