Old 06-19-2005, 03:19 PM   #1
BenBortner
Member#: 50017
2010 Genesis Coupe
Default HELP!!! Screwed up idle after clutch install!
abcde
BenBortner is offline   Reply With Quote
Old 06-19-2005, 05:23 PM   #2
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Take both the cruise and throttle cable off the throttle body. Sounds like you kinked the cable and is putting tention on the. Make sure the throttle body is completely closed.
Patrick L is offline   Reply With Quote
Old 06-19-2005, 05:30 PM   #3
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
i had similar problem when i installed my CAI, i ended up having some materials stuck in my thorrtle body though, which i got rid of.
Impreza2003 is offline   Reply With Quote
Old 06-19-2005, 06:31 PM   #4
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 06-19-2005, 06:32 PM   #5
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 06-19-2005, 06:33 PM   #6
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 06-19-2005, 07:05 PM   #7
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Originally Posted by BenBortner
I guess I should mention that I changed the clutch by pulling the engine forward
That was you first mistake. It's easier to drop the tranny to get too the clutch.
Old 06-19-2005, 07:10 PM   #8
BenBortner
Member#: 50017
2010 Genesis Coupe
abcde
Old 06-20-2005, 07:16 AM   #9
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Next time you try and do a clutch on your impreza, and pull the engine foward be sure to disconnect the throttle cable. I did my clutch just like you did: by using a cherry picker and pulling the engine foward. When everything was put back together it ran fine.
X4 SRT is offline   Reply With Quote
Old 06-20-2005, 10:14 AM   #10
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
If I don't have a lift I just put the car on jacK stands and use a floor jack to lower it down and put it back up. Axles will slide off as you work the tranny back and down.
Old 06-20-2005, 11:56 AM   #11
BenBortner
Member#: 50017
2010 Genesis Coupe
I did, we just routed it wrong. Its all good now though.
VERY Rough Idle after clutch install Scoobie2.0 Newbies & FAQs 8 10-04-2009 07:44 PM
no idle after clutch install eveofrevolution Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-26-2009 03:39 AM
Need help with starter after clutch install. (Pics Provided) MAJRMSA Electrical & Lighting 0 10-16-2008 11:07 PM
HELP!!! Screwed up idle after clutch install! BenBortner North West Impreza Club Forum -- NWIC 1 06-19-2005 07:15 PM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-12-2001 12:35 AM
