Closed Thread
Old 06-19-2005, 02:28 PM   #1
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Default 03 WRX, honk the horn blow the fuse...
Ok so car came back from the body shop. Horn was not working. I looked and the fuse was popped. I replaced it, honked and nothing. Looked and the fuse was popped again.
Any ideas where to start looking to fix this?
ebeck is offline
Old 06-19-2005, 03:12 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Bad horn, bad relay or pinched wire someplace. If it worked before the body work make the shop fix it.
Mulder is offline
Old 06-19-2005, 06:51 PM   #3
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Problem is bodyshops take thier sweet freakin time......
Wire is a given, ground or something. I hate tracing wires so...
So a bad relay could cause this?
Or a Bad horn could cause this?
ebeck is offline
Old 06-19-2005, 07:14 PM   #4
WRXRgr
Member#: 54942
2004 WRX
More likely the (+) wire after the horn relay, on the way out to the horn. You press the switch, relay actuates, current flows and grounds out thru a cut in wire jacket somewhere. Was it in the shop for front end work?
WRXRgr is offline
Old 06-19-2005, 07:16 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...bet it's a pinched wire.
Uncle Scotty is offline
Old 06-19-2005, 11:56 PM   #6
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
No it was in the shop for a respray. No damage at all. Just had custom work and paint done.
Can I trace the wire or is it in the loom?
ebeck is offline
Old 06-20-2005, 12:16 AM   #7
WRXRgr
Member#: 54942
2004 WRX
Hmmm...Ok.
The horn leads are pretty easy to trace, from the horns to the edge of the radiator...after that they're buried pretty well.
I'd pop the front grille and take a look at the horn leads. Make sure they're attached to the horn's terminals correctly, not stuck to some errant hunk of metal by a lazy masker (hey, ya never know!).
Pull the leads on both horns loose and set them so they're not contacting the chassis anywhere. Re-fuse the circuit, press the horn button...if fuse blows, there's a problem in the wiring or relay. Pull the relay, use your multimeter to check for continuity between chassis ground and the horn lead...if there's no continuity, replacing the relay would be the next step.
If fuse doesn't blow, hook up one horn and try it, then the other.
WRXRgr is offline
Old 01-30-2012, 08:58 PM   #8
tkimball86
Member#: 306631
Cool Horn
My horns were not working when i got my 02 wrx wagon.no blown fuses at all and the relay was clicking on and off.tried taking out the horns and cleaning all the grounds and connections and still nothing.so just for grins i went to the local parts store and got a new relay and BOOM horns are good as new.so even if the relay is clicking on and off try replacing it.was only like 6-7 bux
tkimball86 is offline
Old 01-30-2012, 09:09 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Please let the 7-year-old thread lie.
Mulder is offline
Closed Thread
03 wrx new battery horn wont stop ? newgensti Electrical & Lighting 2 04-30-2007 10:52 PM
Help can't get 03 WRX 5 speed separated from the block. SpaceGhost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-21-2007 06:38 PM
SoCal: 03 WRX Door Panels. $50 for the set!!! wal.lin Private 'For Sale' Classifieds 26 02-23-2006 02:50 PM
are the 02-03 WRX Sedan and Wagon hoods the same? efongabonga Interior & Exterior Modification 2 05-15-2003 07:52 PM
prices for '01-03 wrx projector headlights increase when the '04 comes out? poopooscrum Interior & Exterior Modification 7 01-08-2003 06:14 PM
