Old 06-19-2005, 03:30 PM   #1
suren27
Member#: 67464
05 Stock what?
Too Low #009
Default STi HIDs
If anyone is good with the STi HIDs please either PM me or respond here.
The situation is as follows, cleared headlights. Everything was good, no condesation, no leaks. Road trip upto Canada from NY. Once up there realized one HID went out, there was some condensation and water in it. Me = . Now Since I am back home in NY, swapped the bulbs, the "bad" bulb works in the good assembly. Where do I go from here ... warranty is not really an option as the headlights have been tampered with and itll be evenident. Dont ask .. baking accident, headlight leaned over. How do I go to find out if it is the ballast or ignitor or what are my options.
Thanks..
Suren
suren27 is offline   Reply With Quote
Old 06-19-2005, 05:14 PM   #2
suren27
Member#: 67464
05 Stock what?
Too Low #009
Its that grey thing they call the ballast ... what fun. Any ideas to either try to fix it or dry it?
Old 06-19-2005, 07:53 PM   #3
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Several people have had the same problem. IIRC, you can 'bake' the ballast to dry it out. If you do a little searching you should be able to find time/temp suggestions.
jac04 is offline   Reply With Quote
Old 06-19-2005, 08:32 PM   #4
white-shadow
Member#: 78907
ballast should be the thing that says 'Ichiko' -> something around that..hehe
white-shadow is offline   Reply With Quote
Old 06-19-2005, 11:05 PM   #5
2phless
Member#: 69343
2000 nothing good
slow
Let the balast dry. Reopen the headlights and seal them with black RTV. To dry out the balast, unplug it and set it out for a while. If you don't have much time, spray it with starter fluid or tuner cleaner and blow it dry with compressed air. The location being on the bottome of the headlight assy isn't the greatest. But then again, I'm sure subaru didn't intend for us to dismantle every part of their cars like we do.
2phless is offline   Reply With Quote
Old 06-20-2005, 09:57 PM   #6
suren27
Member#: 67464
05 Stock what?
Too Low #009
It was the ballast and I did dry it and fix it and everything. Thanks for the advice guys. I also resealed it with rtv clear silicone ... sorry didn't do black =/. Company was permatex if it matters at all.
Now the only problem I have left is the motor for the leveling ... The left one works, the one without any water ever, the right one on the other hand which had water in it, does not. I do hear clicking when the switch is turned. But nothing happens just the clicking, any ideas or suggestions?
Old 06-21-2005, 09:46 AM   #7
suren27
Member#: 67464
05 Stock what?
Too Low #009
bump?
Old 07-02-2005, 06:47 PM   #8
suren27
Member#: 67464
05 Stock what?
Too Low #009
bump guys?
Old 07-04-2005, 06:51 AM   #9
garie
Member#: 26607
2002 wrx wagon
covered under warranty?
garie is offline   Reply With Quote
Old 07-04-2005, 08:41 AM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Re-read his first post, he cleared the lights and didn't seal them properly, and they got water in them. Warranty doesn't apply.
Old 08-03-2005, 05:58 AM   #11
Imprezv
Member#: 92440
'05 STi
PSM/Gold
Subaru Stars
Suren worse case you could try to order new housing, but prolly costs too much. Maybe spend sometime on ebay or in junkyards hunting these elusive head lamp housings. Hope this helps.
Imprezv is offline   Reply With Quote
WTT or sell: my sti hid lights for sti non hid ohHello Private 'For Sale' Classifieds 5 05-31-2005 11:54 AM
WTT or sell: my sti hid lights for you sti non hid lights. ohHello Tri-State Area Forum 4 05-31-2005 07:13 AM
EVO HIDs > STI HIDs? volkl23 Electrical & Lighting 12 10-26-2004 01:18 PM
Used STi HID or Non HID norseone Private 'Wanted' Classifieds 5 08-15-2003 12:54 PM
STI hid vs. stock HID Genner Interior & Exterior Modification 6 02-14-2003 09:47 AM
Message Board Statistics All times are GMT -4. The time now is 02:58 PM.
