Old 06-19-2005, 04:19 PM   #1
MustangRacer
Member#: 89551
Default Turboing my 2000 Legacy.
I recently purchased a 2000 Legacy GT Limited.
For 165hp the thing crawls.
Would like it to be equaly quick as my 1998 Grand Prix GTP.
So i was thinking of putting together a turbo kit for it. I keep finding parts for the impreza. Will impreza engine parts work on the EJ25 that my legacy has?
I also saw some kits for about $1995, anyone have any experience with low priced kits like this
btw its an auto tranny. would any upgrades to the tranny have to be done?
MustangRacer is offline   Reply With Quote
Old 06-19-2005, 06:58 PM   #2
nyyankees003
Member#: 71877
2003 Legacy L SE
Mystic Blue Pearl
i wouldnt know but the GT only has 165hp? that seems low but hey im n/a so what do i know lol
nyyankees003 is offline   Reply With Quote
Old 06-19-2005, 08:47 PM   #3
kevinsUBARU
Member#: 2263
2012 Impreza Sport
165hp is corrrect sir
kevinsUBARU is offline   Reply With Quote
Old 06-19-2005, 09:47 PM   #4
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
search for my name and also JoeT you will find a lot of info. you can use RS kits on the legacy, you need to remove the passenger side strut brace and the cruise control module for a turbo and downpipe to fit.
you dont need to upgrade your auto but it doesnt cope with the added torque too well, my auto was slipping at only 6psi.
i am selling my current turbo setup if you are interested however it is not cheap, i went the more spendy route with nicer components. FYI turboing the EJ25 is not cheap, and trying to do it cheaply will end up with problems. remember this, its all about engine management and tuning.
Ben
Old 06-20-2005, 07:56 AM   #5
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
my offerings:
1. why turbo and not WRX swap? prolly the same amount of $ and much more reliabilty aftermarket support.
2. if you were so concerned about speed, why'd you buy an auto?
it crawls? you did test drive it before you bought it, right?
iamrazor is offline   Reply With Quote
Old 06-20-2005, 10:58 AM   #6
tora
Member#: 5851
09 Forester XT
+ NA Miata
For your auto you can get a torque converter which will help cope with the power. AVO has a turbo kit that is supposed to be pretty decent.
tora is offline   Reply With Quote
Old 06-20-2005, 12:14 PM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
AVO's turbo kit is very expensive, but looks very well designed. If someone were content with putting the money into it and not doing any legwork (or phonework, or fingerwork, etc), they could come away with a significantly faster Legacy.
nyyankees003: all Legacies between 2000 and 2004 had the same engine with the same power. The OB had the 3.0 H6.
PHATsuby: do you have a page or link with the info on your old setup?
DLC is offline   Reply With Quote
Old 06-20-2005, 12:55 PM   #8
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
DLC beat me to it. I was about to let nyyankees003 know that the legacy GT did NOT get better power vs his legacy L or the leagcy Outback. The difference is in the suspension and trim levels, not horsepower... And the car does crawl compared to some other models in the same class, but other models in the same class have turbos or v6 engines. It does not crawl compared to other 4 cyl non turbos... And the auto legacy models are known for being slower and more sluggish than the manual models... Do a wrx swap and you'll be happier... Or just take a cue from all the civic owners and put a huge wing on your car to go fast. It is MUCH cheaper than a turbo...
janikphoto is offline   Reply With Quote
Old 06-20-2005, 01:04 PM   #9
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
or just add a type R sticker
Old 06-20-2005, 01:08 PM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
the torque converter doesnt really help cope with power, or at least in my experience it didnt. that will help you launch better, however my issues came when shifting, the valve body just could not deal with it and would slip on shifts, this came at only 6psi for me i believe. guys with auto RS's were running 6psi on their autos no problems, i think the increased weight of the legacy was part of the problem.
DLC-I have a list somehwere but i'll repost it here.
Mechanicals:
T3/T04B turbo
ludespeed uppipe
ludespeed downpipe 2.5" no cats
Tial 38mm wastegate
Blitz BOV
Spearco core(6x18x3) TMIC
Fuel:
wrx injectors
injector adapters
Supra TT fuel pump
Engine Management:
Autronic SMC w/custom dwell chip, reluctor interface
J&S safeguard
Exhaust:
2.5" Brullen catback single tip quiet acoustics
that should about do it.....
Ben
Old 06-20-2005, 02:15 PM   #11
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
I will have to disagree on this one. I have driven a bunch of NA 4 cyl's and most are faster than my MT legacy. I think the biggest killer is the power loss to AWD. I have not seen any numbers but I would be guess I am only putting a bit over 100HP to the ground, once again I could be wrong but either way this car is not fast. It does handle like a dream though.
bhall is offline   Reply With Quote
Old 06-20-2005, 07:26 PM   #12
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Yeah if you're going to turbo your EJ25 spend some time on the Aftermarket Turbo forums here on NASIOC (I know most people are Impreza 2.5RS owners but it's pretty much the same thing.) There are a lot of stories of projects gone wrong, so use the wealth of information that's available here.
A WRX swap can be just as cheap as a turbo kit if you are comfortable with lots of wiring. If you pay someone else to do it it can get expensive. Spend time on the Subaru Conversions forums if that's what floats your boat.
The one thing I wonder about a WRX swap is if it would be any fun mated to an automatic transmission... you think your NA Legacy is slow, try test-driving a Saab 9-2X turbo (basically a WRX wagon) with an automatic transmission some time - the way automatic transmissions shift don't work so well with a small-displacement turbo motor with no torque down low.
The BE/BH 2000 Legacy feels slower than many other cars with 165hp cause it's so heavy... with all the "Limited" trim equipment and such I'm sure it's close to 3300 pounds.
jey is offline   Reply With Quote
Old 06-20-2005, 10:24 PM   #13
RiverDog
Member#: 65661
126 whp, 141 wtq
That's how I roll
I picked up a 2001 Leg GT 5MT a couple months ago. It's a dog compared to my 4Runner and Celica GT-S. I can see where a little turbo, spooling quickly, would really make a big difference in the car.
Does anyone know if the AVO kit is CARB/smog approved? Being in Illinois, CARB approval doesn't mean much except it's got a good shot of passing.
Also, $4500 for a well-constructed turbo kit is a bit much but it's not obscene. I'd hope you get what you pay for. Blitz released a S/C for the GT-S thru Trial that ran in the $6500 range. Now, that is obscene.
Last question for those in the know: $4500 gets you the kit. Any idea how much install and tune would be? Is it a relative easy tune or a tricky one?
RiverDog is offline   Reply With Quote
Old 06-20-2005, 11:07 PM   #14
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
If you want, I have some ludespeed pipes that I want to get rid of, They were made for an automatic (gotta compensate for beefier tranny)
It would be wise to put a tranny cooler on there too.
Tizzle is offline   Reply With Quote
Old 06-21-2005, 01:52 AM   #15
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Even more than that, my friend. Curb weight on a GT Limited is 3370#. There are a few reasons I chose not to "upgrade" from my BD to a BE, and probably the biggest reason is it's the same overworked/underpowered drivetrain in a car that weighs 200# more!
Yeah, what he said!
Pat Olsen
'97 Legacy 2.5GT sedan
Old 06-21-2005, 02:26 AM   #16
nyyankees003
Member#: 71877
2003 Legacy L SE
Mystic Blue Pearl
so wait the L and the GT have the same power? why do the GT's have a turbo but have the same power as the n/a L?
Old 06-21-2005, 06:51 AM   #17
SubaruGenki
Member#: 65058
02 Eagle Summit
TSi
00-04 LGT's don't have turbo.
SubaruGenki is offline   Reply With Quote
Old 06-21-2005, 02:39 PM   #18
MustangRacer
Member#: 89551
Thanks for everyones responces. THe WRX swap is more of a job then i would want to do...all of this was going to be done by myself.
PHATsuby, thanks for the parts list... i'll look into those thing!
The car is my wifes daily driver...she doesn't know how to drive manual trans.
Old 06-21-2005, 04:15 PM   #19
finse46
Member#: 30756
2006 Legacy GT SpecB
Artic Silver
I have been considering an engine swap for my 01BE for about a year now. Subaru introduced the 2.5T in the Forester/Baja lin the last couple of years, and now that the LGT is a 2.5t, I think these drivetrains will become available at reasonable prices fairly soon (used from wrecked cars, etc..).
finse46 is offline   Reply With Quote
Old 06-21-2005, 04:23 PM   #20
tora
Member#: 5851
09 Forester XT
+ NA Miata
They're all ready pretty reasonable if you know where to look.
Old 06-22-2005, 02:45 AM   #21
nyyankees003
Member#: 71877
2003 Legacy L SE
Mystic Blue Pearl
wow sorry guys lol i guess i shoulda known that...thanks!! go newbies eh?
Old 10-11-2009, 10:01 PM   #22
derrickmd18
Member#: 226352
raising the dead but is there a way to keep the cruise control and go turbo?
derrickmd18 is offline   Reply With Quote
Old 10-12-2009, 03:48 AM   #23
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Since the CC is cable driven, I don't see why you couldn't relocate the actuator. It would be a bit of a PITA but doable.
Old 10-12-2009, 08:12 AM   #24
PHATsuby
Member#: 13617
2001 Legacy GT back
yea would prob take a little ingenuity finding a new mounting location but is definitely doable.
Ben
My 2000 Legacy 2.5T JoeT Legacy Forum 126 10-27-2008 07:13 PM
bi-turbo on 2000 legacy wagon? disaster999 Newbies & FAQs 6 08-15-2005 09:07 AM
Looking at: MY 2000 Legacy L Sedan Chi_San Legacy Forum 8 06-22-2004 10:01 PM
wrx turbo for 2000 legacy utarch00 Legacy Forum 12 10-16-2002 08:28 AM
MY 2000 Legacy and Outback owners - FYI Jon [in CT] Legacy Forum 0 05-11-2001 01:05 PM
