#1 |
John Wayne Toilet Paper
Moderator Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
ok after installing my speakers in the front and installing new speaker wire for the rear doors (routed pretty easily through the stock rubber tube from doorjam to door!), I have some questions regarding the rear doors.
The stock "Upgraded Speakers" look like standard 5 1/4" speakers. What aftermarket components, coaxials, or mids have you been successful installing in this location for a '02 WRX ? What modification (if any) did you have to make? thanks!
#2 |
Member#: 8857
Vehicle:2002 WRX Silver |
I replaced my rears with 4" rounds. The problem that I ran into was that the cast basket for my new speakers was ~1/8" thick vs. the stock spekaer which was a piece of thin sheet metal. When I mounted my replacement to the plastic weather shield and then re-inserted, I didn't have the clearence to put the door panel back on.
I ended up building a mounting bracket that comes in from the back of the door and it works now (didn't use suby's plastic weather shield). If you go with a speaker that has a sheet metal basket then you shouldn't have any problems just using suby's weather shield. My stock speakers that I took out were 4" rounds, but I didn't opt for the upgraded stereo from subaru. I also found the fronts to be 5.25's, which was a bit of a disappointment. Does the upgraded stereo system get you bigger speakers as well? |
#3 |
Member#: 4135
BAIC
Vehicle:2012 NBA West Conf. MVP |
do u really only get 5 1/4" in front? & only 5 1/4" fit in the rear doors???? Dooh
MY01 6 1/2" in front, back and (for me at least) in the rear doors too!!! How much deeper is a 6 1/2 than a 5 1/4? |
| Thread Tools | |
| Display Modes | |
| FS IL: NIB Kenwood KFC-1061S rear door speakers, for WRX | TKDKracker007 | MWSOC Private Classifieds | 5 | 02-11-2010 01:25 PM |
| Quick Fix: Rear OEM speakers on WRX | Cobra's WRX | Car Audio, Video & Security | 8 | 09-14-2009 04:12 PM |
| installing front and rear door speakers on my 05 WRX | g_$ | Car Audio, Video & Security | 7 | 04-23-2009 12:29 PM |
| Advice on grinding rear door speaker cut-outs | WRX469 | Car Audio, Video & Security | 6 | 12-22-2003 09:29 PM |
| New WRX rear door speaker cutouts | Porter | Car Audio, Video & Security | 3 | 01-17-2001 02:46 PM |
