Old 06-19-2005, 11:42 PM   #1
25psi
Member#: 3086
2001 2.5 RS
Default Brake Booster Check valve
Hello all.
Anyone knows where it is and what its for?
Any pic or diagram would be very helpful.
Thanx a ton.
25PSi
25psi is offline   Reply With Quote
Old 06-20-2005, 08:48 AM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Its in the vacuum line running to the booster. Its there so that when you go into boost, you don't pressurize and blow up the booster. A good thing to have - if you have a turbo.
OneOBS is offline   Reply With Quote
Old 06-20-2005, 02:24 PM   #3
Member#: 47261
Actually you wouldn't blow up the booster. I know someone that replaced that vaccuum hose with one without a vaccuum check... all it does is blow air into the cabin behind the brake pedal when you boost.
in case you are wondering, it's a little bulge in the hose going from the intake manifold to the brake booster. It can't be removed or inserted, and it comes in the hose. It is only available through subaru.
soccer_freak_m@hotma is offline   Reply With Quote
Old 11-10-2009, 07:51 AM   #4
ryanmcarthy
Member#: 215363
2005 Impreza STi
If something is wrong with this, would it cause an Engine Check light to come up on the dash, with error 'Brake Booster Valve' ?
ryanmcarthy is offline   Reply With Quote
EJ20G swap...will I need brake booster check valve?!? xlur8ed Pre-2002 Factory Turbo Powertrain 2 04-18-2008 11:26 PM
brake booster check valve? rob Subaru Conversions 15 12-07-2006 03:33 PM
brake booster problem or possibly check valve.. scobaru Brakes, Steering & Suspension 2 03-20-2006 01:38 PM
brake booster line check valve Tim Sanderson Subaru Conversions 7 06-20-2005 01:57 PM
adding a brake booster check valve TURBODUDE427 Brakes, Steering & Suspension 5 04-12-2004 09:21 AM
