Old 06-20-2005, 06:25 AM   #1
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
Default is it normal for my car to...
idle at 200-300 rpm? after its warmed up and everything it will idle really really low. 250 is about average for it being warm.
svek is offline   Reply With Quote
Old 06-20-2005, 07:56 AM   #2
sha_zapple
Member#: 41012
1998 Legacy L
There is no 200-300 rpm. The Tachometer starts at 500, so its actually idling at 700-800, which is normal for my car.
sha_zapple is offline   Reply With Quote
Old 06-20-2005, 09:23 AM   #3
Nicklbrso
Member#: 44887
00 GC6
Yes, the EJ25's are known to idle low. Mine does the same.
Nicklbrso is offline   Reply With Quote
Old 06-24-2005, 12:54 PM   #4
abosworth
Member#: 53856
2012 Speed3
Red Mica
Mine also idles really low. 500-800 rpms. nothting to worry about
abosworth is offline   Reply With Quote
Old 06-24-2005, 12:58 PM   #5
Dash_Martino
Member#: 78728
04 STi
yeah ddue i thought the same thing when i got my car. like they said, tach starts @ 5. no worries!
Dash_Martino is offline   Reply With Quote
Old 06-24-2005, 01:09 PM   #6
protocall
Member#: 38348
yeah it's when it idles so low that the car starts to buck like it is about to run out of gas that you need to worry. or it idles from real low, then to about 2-3k RPMS back and forth. i've had that problem due to bad temp sensors before.
protocall is offline   Reply With Quote
Old 06-24-2005, 09:07 PM   #7
balajc
Member#: 15393
MY00 2.5RS Coupe 5MT
Silverthorn Metallic
very easy for a noob manual driver to stall a car with the EJ25 in it. Trust me, I know
balajc is offline   Reply With Quote
Old 06-25-2005, 02:48 PM   #8
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
As long as your car doesn't shut off its fine. Plus if u put a loud exhaust on the low idle helps passing the db test
Caplin 2.5 is offline   Reply With Quote
Old 06-26-2005, 12:42 PM   #9
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
An exceptionally low idle can actually harm the crank and rod bearings. I've heard of this happening specifically in V-Twins like HD, when the owners will turn down the idle so it sounds cooler.
DLC is offline   Reply With Quote
Old 06-26-2005, 06:17 PM   #10
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I doubt it's actually idling that low. Like has been said, tach starts at 500, so the only way you could know it was idling lower was if you had a computer that could monitor that. 700 is about normal, which would be the 2nd tick on the tach.
HondaH8er is offline   Reply With Quote
Is it normal for my "sent" folder to be empty after sending a private message? ZZcorollaVV_Ti Newbies & FAQs 8 07-10-2008 04:01 PM
Is it normal for my car to be this bouncy? super laubo General Community 37 09-28-2007 09:28 AM
Is it normal for my Alpine amp to run hot? WimpWgn Car Audio, Video & Security 12 08-25-2005 11:46 AM
loud turbo noise. Is it normal for turbo car? myfirstnewcar Warranty Issues & SOA Problems 11 03-07-2002 06:10 PM
Is it normal for a car to smoke after an uppie installation? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-11-2002 03:58 AM
