#1 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
Can anyone tell me what the difference between the two crossover pipe gaskets are? They are unique part numbers and one is 2x the cost of the other. I have one of them, but need the other, and don't know which one I have.
#2 |
Member#: 8512
South East
#3 |
Vendor
Member#: 41252
SWIC
Vehicle:Twin 2005 600WHP FormulaD/TimeAttack Sti's |
They are actualy interchangable. One has a tab that sticks out of the gasket. I have no idea why. I am sure someone else will know. Was told it was for heatshield and then I was told it was a heatsink to keep the gasket from deforming. Who knows.. When I put mine back together I used two of the cheap ones. No issues.
Clark |
#4 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
jeff, to go along with clark's observation, i think the tab may be so that the installer can hold it in place while bolting it up?
in any event, i have never replaced mine and i've never had a problem with either end. xover has been on/off the car maybe 5 times. i know you'd like to do everything perfectly, but you might save a few bucks you didn't need to spend in the first place. it'd buy at least half a tank of gas! ![]() |
#5 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
one with a "tab" is a heat dissipator since it is close
to the oil filter. the tab points toward the filter.. and other looks like a regular gasket.. |
#6 |
Member#: 8512
South East
Dissipating heat toward the oil filter seems counter-intuitive to me.
Weird. Weird also that the 2002 FSM does not indicate any tab nor orientation of said tab. Oh well. |
#7 | |
Member#: 32792
NESIC
#8 |
Member#: 16274
Vehicle:2001 GM6 2.0L vf30 e30 black/rust |
yeah, the one on the uppipe side has the triangle "heatshield" on it.. dont know why.. but thats the way it is. I just replaced that one last week.
| Thread Tools | |
| Display Modes | |
| FS: 2 New Exhaust manifold crossover pipe gaskets | Bariga | Engine/Power/Exhaust | 4 | 01-17-2010 07:36 PM |
| FS: Remiflex crossover pipe gaskets | cjx17 | MWSOC Private Classifieds | 1 | 10-26-2007 01:09 PM |
| water crossover pipe gaskets! | dukeduster | Built Motor Discussion | 4 | 10-05-2006 08:20 PM |
| PN: Gasket between Drivers manifold and crossover pipe? | ScoobySnacker | Factory 2.0L Turbo Powertrain | 3 | 07-11-2006 12:23 PM |
