Old 06-20-2005, 02:54 PM   #1
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
Default Help with Morettes
Ok so I installed my morettes and all of the lights are working except for the passenger side low/regular beam. I am not sure if I have all the wires hooked up. But on the passenger side i have two wires connected to the line that is coming from the driverside light, a big plug that connects to the car side big plug, and a small plug that plugs into the car side small plug. I looked at the bulb and it looked fine. I have a pic of the light...the only thing i can think of is these two wires I have circled...i dont have them connected to anything. They are both female ends, one is grey, one is yellow. I see no where to plug these in. Please help. Thanks. btw, i bought them used off of here so it looks like all the splicing and what not is already done.
Here is the pic...
Justin
jdgrimm is offline   Reply With Quote
Old 06-21-2005, 04:28 AM   #2
Genner
Member#: 18372
for some reason....while looking at my friend's Morettes, he has another relay right below the existing one...it screws into that empty hole in the pic.
Not really sure what's it for though...i will try to figure it out and keep you posted
Genner is offline   Reply With Quote
Old 06-22-2005, 12:54 AM   #3
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
ok thanks..that would be great.
Old 06-22-2005, 02:02 PM   #4
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
bizump
Old 06-22-2005, 03:47 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Those lights have been messed with, aside from the missing relay some other things may be changed as well. You can just do away with all that anyway, connect the low beams to a direct ground and the need for the relays is eliminated. Plus they'll be brighter than with the switched grounds.
Old 06-23-2005, 09:09 AM   #6
Chriss2482
Member#: 84202
2006 WRX STi
i wonder if that connector with the red yellow and black wires is the thing i need...
Chriss2482 is offline   Reply With Quote
Help with Morettes install BeavisNuke Interior & Exterior Modification 4 04-04-2003 06:16 PM
Help with Morettes - please Rodeo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-15-2002 07:45 AM
Please Help With Morettes!!! maxum66 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-03-2002 10:39 PM
Help with morettes?!?!?! beingmarc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-21-2002 09:58 PM
Need help with morette lights jeffsnyder Interior & Exterior Modification 2 01-03-2002 09:44 PM
