Old 06-20-2005, 03:08 PM   #1
brex16
Member#: 78703
2004 WRB STi
Default AP stage 2 question
Will flashing to Stage 2 help get rid of the stink on my catless exhaust?
brex16 is offline   Reply With Quote
Old 06-20-2005, 03:19 PM   #2
Amplified2000
Member#: 86389
2012 HyundaiVeloster
Blue with salt accents
Nope.. nothing other than a catylitic converter will get rid of that smell. Look into a metal-substrate style high flow cat, most say that if flows almost as well as an open pipe.. maybee 5whp loss at most.
Amplified2000 is offline   Reply With Quote
Old 06-20-2005, 03:21 PM   #3
brex16
Member#: 78703
2004 WRB STi
yea, well i just thought that the stage 2 reflash would lean the engine out a bit. Correct me if im wrong but the stink isnt caused by removing the cats, its caused bc the engine is running rich and there is no cat there to obsorb it.
Old 06-20-2005, 04:20 PM   #4
Amplified2000
Member#: 86389
Originally Posted by Cobb
Target A/F Ratios are mid 12's under load before the onset of boost. Under full
load by 4000 RPM the A/F Ratio will drop to mid 11:1 and gradually run richer as
RPM's increase ending at mid to high 10:1 A/F at redline.
That is taken from the map notes for the Stage 1 93oct flash
load by 3500 RPM the A/F Ratio will drop to mid 11:1 and gradually run richer as
That is from the notes for Stage 2 93oct...
As you can see they have the same target A/F ratios so going to stage 2 will not lean out the engine at all. Would you rather lean your engine out and risk detonation, install a high-flow cat with little to no change in power or drivablity, or contiue on with the stink?
For me the choice is pretty obvious.
Read thru the map notes Here to familiarize yourself with the differences between AP maps.
Old 06-22-2005, 12:30 PM   #5
SkirtBoy
Member#: 11056
2009 MB CLK 350 CPO
Black on Tan
SkirtBoy is offline   Reply With Quote
Old 06-22-2005, 12:51 PM   #6
ChgoJay
Member#: 71722
2004 WRX ZINGER!!!!
WORLDRALLYPLATINUMBLING
Originally Posted by SkirtBoy
Now its a party!!!!!!!!!
ChgoJay is offline   Reply With Quote
Old 06-22-2005, 01:10 PM   #7
johsti
Member#: 36049
2004 WRX wagon
I'm running Cobb stage 2 with one hiflo cat, and I still get the catless stink until my cat gets hot (about half hour of driving or so). I plan on getting dyno tuned in the near future, and hope that will get rid of the smell.
johsti is offline   Reply With Quote
Old 06-22-2005, 01:15 PM   #8
ranger5oh
Member#: 77752
5Sti 2005 Sti
With a high flow, you should get no smell. Im running a stage 2 with some additional tuning, and I get no smell... even before the extra tuning.
If you have no cats, go get one. That will solve your probs.
ranger5oh is offline   Reply With Quote
Old 06-22-2005, 01:26 PM   #9
AlboWRX
Member#: 37719
2003 WRX
Wuss...
AlboWRX is offline   Reply With Quote
Old 06-22-2005, 01:47 PM   #10
johsti
Member#: 36049
2004 WRX wagon
http://forums.nasioc.com/forums/showthread.php?t=786318
Apparently, I'm not the only one.
AP stage 2 question iamchris Newbies & FAQs 1 03-05-2006 12:32 AM
AP Stage 2 Question USF97J4x4 General Community 5 01-19-2006 05:34 PM
Cobb AP Stage 2 question MBasile Engine Management & Tuning 8 11-10-2005 05:35 PM
Cobb ap stage 2 question.... DeKaP Newbies & FAQs 9 09-15-2005 05:30 PM
AP stage 2 question txl146 Engine Management & Tuning 6 04-14-2005 09:02 PM
Message Board Statistics All times are GMT -4. The time now is 02:04 AM.
