Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 08-06-2001, 01:02 PM   #1
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Default Warning: some 15" rally wheels do not fit WRX
My mechanic, Bert Arano at Union 7 is preparing a ProRally WRX right now. He ordered the usual Subaru fitment rally wheels from Compomotive in England. They were 15x7x50mm offset and they do not clear the caliper. The interference is slight--a 45 mm or less offset would be fine. He also test fit Revolution RFXs with the same result. This is with the stock U.S. front brakes, BTW. I'm lending him 35mm offset Compomotives from my Celica 'til he can get the right ones from England. That'll be one wide track rally car!
The issue seems to be that the rally wheel manufacturers use different castings for different offset ranges. The 50mm offset was at the positive offset limit of that particular casting. Therefore there was very little space between the mounting surface and the part of the rim where it flares to meet the spokes.
So do not assume that if you just tell the wheel vendor "to fit a Subaru" everything will be fine. The new WRX is different enough from prior models that it's not an automatic fit. Make sure that that particular wheel in the specific offset has been tested on your car.
Jon Bogert is offline   Reply With Quote
Old 08-06-2001, 01:17 PM   #2
pbnj9786
Member#: 4473
MY10 STi
Plasma Blue Pearl
these 15s do, they even fit the STi Brembo brakes.
STi, perfect fit everytime.
pj
pbnj9786 is offline   Reply With Quote
Old 08-06-2001, 01:57 PM   #3
SHADOWES
Member#: 4427
1998 Legacy GT
silver for now
thoes are cool wheels... I whish I could have them...
SHADOWES is offline   Reply With Quote
Old 08-06-2001, 03:01 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
15x7" +50mm Raceline RL-7s will also fit the stock US-spec WRX brakes. I tried mine out on a WRX at a track event a couple months ago just to see if they would clear.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 08-06-2001, 03:13 PM   #5
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
Smile
Good suggestions both. I posted this just to point out that a couple of seemingly "obvious" 15" rally wheel choices require a little more care to make sure they fit.
Old 08-06-2001, 04:06 PM   #6
Dave_Clark
Member#: 1015
Jon, those Compomotives would probably fit the 4-pot calipers that the rest of the world gets on the standard WRX. Trouble is, we get the sliding calipers and with the larger diameter rotors the caliper will touch the wheel where the 4-pot caliper does not. Like Patrick said the Racelines have enough clearance and fit. The Minilite rally wheels just barely touch with brand new brake pads. After the pads wear down a bit the caliper slides in and clears.
Dave_Clark is offline   Reply With Quote
Old 08-06-2001, 04:06 PM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Thumbs up
thanks Jon!!!
there are loads of wrx's popping up in the rally scene and this is indeed useful information!!
j.
www.subiegal.com
Old 08-08-2001, 04:23 AM   #8
iceweazel
Member#: 6816
01 yeller wrx
triumph tiger,klr,cb900f
Were those RFX's new? Which offset? Been talking to
Tom Tat. about a set to fit over 4 pot group Ns.
Very worysome.
Ed
iceweazel is offline   Reply With Quote
Old 08-08-2001, 09:20 AM   #9
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
Don't worry-- the whole world knows about the Subaru 4-pots and what wheels fit over them. The issue here was the 2 piston stock WRX calipers on a PGT car. I don't have a template but they must stick out a bit further to the rim or face than the 4-pots.
Old 08-08-2001, 03:22 PM   #10
Dave_Clark
Member#: 1015
Yes, they do.
Old 08-08-2001, 03:56 PM   #11
Idjiit
Member#: 5310
2013 Sonic Turbo
Thanks for the head's up, Jon. I was contemplating getting the compmotives, but looks like I'll be going with the RL-7's instead.
Idjiit is offline   Reply With Quote
They're here ..... 15" rally wheels for the WRX [email protected] Tire & Wheel 37 08-27-2007 07:16 PM
15" Rally wheel announcement for the WRX [email protected] Tire & Wheel 30 05-04-2004 01:31 PM
15" OEM steels DO NOT fit the WRX right? newrxnj Tire & Wheel 2 12-15-2003 11:18 AM
GSX/TSI wheels..do they fit WRX? juztin180 Brakes, Steering & Suspension 2 03-25-2002 11:15 AM
15" Subaru Steel Wheels Will NOT Fit WRX silenuskjh Brakes, Steering & Suspension 0 06-13-2001 05:41 PM
