Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 06-20-2005, 04:37 PM   #1
Millencolin!
Member#: 88219
1992 Legacy SS
EJ22t + 16g = :)
Default 2.2L intercooler
I cannot seem to find any website that has TMIC that will fit my 1991 legacy turbo. Does anyone know of a website? TIA!
Millencolin! is offline   Reply With Quote
Old 06-20-2005, 05:08 PM   #2
damonmlime
Member#: 54525
2000 00rs 2x91ss 95l
blue ridge pearl
as far as i know there isn't a direct fit intercooler for our cars, some people have had fairly good luck with some of the older wrx intercoolers, the slanted style that is but they seem to be pretty hard to find, others use the saab 900 ic, its not a direct fit and it's not the most efficient but still alot of ss owners are using it. I think i'm going to go with the usdm wrx ic, there is some modifications that need to be done but it seems to be the best route. check out bbs.legacycentral.org. theres a whole section on intercooling for our cars.
damonmlime is offline   Reply With Quote
Old 06-20-2005, 07:01 PM   #3
Millencolin!
Member#: 88219
1992 Legacy SS
EJ22t + 16g = :)
How do you connect the inlet on the stock WRX IC to the turbo outlet? Becaus eI saw a picture of the Rex IC and it had 2 inlets.
Old 06-20-2005, 10:53 PM   #4
corsair
Member#: 61029
2008 Civic Si
1993 Leg Wagon
ah well I was present for BAC 5.2's install this weekend and you're in luck
however you dont' have an upgraded turbo do you? because BAC 5.2 has a 16G in there and uh, I don't think a WRX IC holds much benefit for the stocker as I think it was decided that you lose charge velocity or something like that
maybe you should try to pick up a Subaru AWIC
corsair is offline   Reply With Quote
Old 06-21-2005, 03:17 AM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
The AWIC is cool, but needs a few things....Pump, hoses, radiator and if you are drag racing, a separate cooler tank.
Mine is great on the road, but at the track it gets plenty hot since I don't have the extra coolent resevoir.
Old 06-21-2005, 08:40 AM   #6
Mgardenier
Member#: 7518
1994 Legacy SS
Aegean Blue Metallic
find an all alum. saab unit, if you are going to use the stock turbo. it good enough for what the stock turbo can deliver. im hunting for an all alum. unit locally, until then its 9psi of hot hot hot air. good luck
Mgardenier is offline   Reply With Quote
Old 06-21-2005, 12:38 PM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
i have seen
wrx intercoolers with one inlet fed one inlet blocked off a flange bolted on the bov port and a remote BOV
a,b type impreza intercoolers (slant style)
my recomndation to you is a forester XT intercooler
its much shallower than the wrx, you will still have to move the bov but it is much easyer to deal with
i have a FXT intercooler ready to go on my ej20G .. its my next project waiting for the fed ex man to deliver my wide band so that i can get car in some sort of tune
Old 06-21-2005, 12:57 PM   #8
Mgardenier
Member#: 7518
1994 Legacy SS
where did you source your fxt intercooler?
Old 06-21-2005, 01:09 PM   #9
Millencolin!
Member#: 88219
1992 Legacy SS
EJ22t + 16g = :)
Well a friend of mine has a EJ20G from a 1995 JDM WRX that I might swap into it, but even then I will still have the stock turbo until I save up for a better one. So I really don't know if its worth even opting for the Saab unit if I swap engines soon.
Old 06-22-2005, 05:06 PM   #10
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
posted in the nasioc forester forum and forester forums (name escapes me)
Old 06-28-2005, 02:10 AM   #11
cowboy74213
Member#: 77267
1993 Legacy
so the forester ic fits just fine with little modification?
cowboy74213 is offline   Reply With Quote
Old 06-28-2005, 12:09 PM   #12
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
no cutting anyway
the stock charge hose is too short -which can be solved by buying a samco hose cutting it, extending it with a metal pipe - also adding a vent on that metal pipe for the BOV then making a plate to cover the factory BOV flange
Old 06-28-2005, 04:20 PM   #13
cowboy74213
Member#: 77267
1993 Legacy
ahh cool im currently looking for ic options for my 93 turbo wagon and would you be willing to email or post some pics of your ic setup?
email: jdew@simla.colostate.edu
Old 06-28-2005, 05:08 PM   #14
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I'd be interested in the forester XT i/c as well.
Even though I already have a Saab i/c in my basement waiting to be put in, I may change my mind if it fits well enough.
IronMonkeyL255 is offline   Reply With Quote
FS: Version 2 STi Intercooler, Subaru Water to Air Intercooler, FSB, 2.2L engine munkis Tri-State Area Private Classifieds 0 11-14-2008 09:32 AM
2.5 injectors in a 2.2l SOHC OBS? cams for 2.2l? kaisersouse Normally Aspirated Powertrain 3 04-02-2006 09:10 PM
Intercooler for 2.2L Turbo Prostho Legacy Forum 21 02-11-2001 08:47 PM
00 2.2L vs. 96 2.2L, where'd the power come from? 96Lconversion Normally Aspirated Powertrain 15 01-19-2001 12:32 AM
'95 2.2L engine same as '97 2.2L? I need the part quick! chyisan Normally Aspirated Powertrain 1 12-22-2000 03:33 PM
