Old 06-22-2005, 08:10 PM   #1
ver5replica
Member#: 88348
Default biggest turbo with 90 degree inlet? and a few ??
my early jdm wrx engine i have in my 93 impreza has a 90 degree inlet for the air intake, whats the biggest turbo i can put in there with that. also can i upgrade to a turbo with the straight inlet? what do i do for the intake? dont they run under the manifold? i have no room for that hopefully someone can help!!
ver5replica is offline   Reply With Quote
Old 06-22-2005, 09:10 PM   #2
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
Deadbolt will do up to an 18G or 20G with the 90 degree inlet IIRC. Talk to Jerry.
You can go to a straight inlet but it will take a lot more work then just getting another one with the 90 inlet. You'd probably have to clock a straight inlet to get it in.
legacy92ej22t is offline   Reply With Quote
Old 06-22-2005, 09:22 PM   #3
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
You'd have th get the up and down pipes modified the orient the inlet somewhere to could use it for a straight inlet.
Jerry already normally carries the 16G with 90-degree inlets, and could probably do just about any other one with it.
IronMonkeyL255 is offline   Reply With Quote
Old 06-22-2005, 09:31 PM   #4
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Don't you already have a TD05?
THAWA is offline   Reply With Quote
Old 06-23-2005, 01:52 AM   #5
azn2yunr
Member#: 67229
9295 BC/gm6
winestone/funky blue
yesir
azn2yunr is offline   Reply With Quote
Old 06-23-2005, 03:34 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
that being the case read post #2
upgrade the compressor wheel to a 18G or 20G
WTB: ej20g td05 16g or other turbo with 90 degree inlet slava from goshen Private 'Wanted' Classifieds 1 03-31-2008 11:00 AM
WTB: ej20g td05 16g or other turbo with 90 degree inlet slava from goshen Private 'Wanted' Classifieds 0 03-01-2008 10:53 AM
wtb: td04 with 90 degree inlet rallymobile Private 'Wanted' Classifieds 2 05-02-2007 11:22 AM
vf10 with 90 degree inlet!??!?! xtian Pre-2002 Factory Turbo Powertrain 30 05-11-2006 12:22 AM
