Old 06-20-2005, 02:41 PM   #1
elcorazon01
Member#: 73988
Default Pedal to the floor! Brake pedal that is.
So I just completed a drum to disc conversion on my 96 Brighton with the parts coming off a 2001 RS. I was wondering if any of you out there in auto land know whether I need to upgrade the master cylinder to accomodate. Also worthy of note: I replaced my one-pot fronts with the stock two-pots off the RS as well. So I guess my question is this: Is the RS master cylinder bigger than that of a Impreza L or Brighton? Thanks a lot.
Andy
elcorazon01 is offline   Reply With Quote
Old 06-20-2005, 06:11 PM   #2
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
I have 4-pots in front, converted the rear to disc's and I dont have a problem w/ my stock master cylinder. I will upgrade to the bigger MC in the future but it seems to work well for me right now.
Rick
RallySport Direct is offline   Reply With Quote
Old 06-21-2005, 12:31 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no proublems here
WRX brakes front 90is legacy brakes rear
no issues with MC size
Old 06-21-2005, 12:57 PM   #4
elcorazon01
Member#: 73988
Thanks for the input. I guess I'll try bleeding them again. The stopping power seems fine but it feels wierd with all the brake pedal travel. Thanks again.
Andy
Old 06-21-2005, 01:15 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
are you bleeding them in order and under pressure?
Old 06-21-2005, 01:48 PM   #6
JDM_Scobaru
Member#: 57809
Haha I had this problem after i did my rear disc swap. You just need to bleed the s**t out of everything and then you will have pressure. Also make sure bleeders are facing the right way, double check everything, and make sure the calipers are on right if you can even put them on wrong. Good luck though I am sure that you'll get everything worked out just fine.
JDM_Scobaru is offline   Reply With Quote
brake pedal to the floor....help!!!!!! 02SkoobyDoo Brakes, Steering & Suspension 3 05-09-2010 08:39 PM
HELP!!! Clutch pedal to the floor!!! eastcoastGC8G Transmission (AT/MT) & Driveline 11 04-07-2010 09:02 PM
HELP!!! Clutch pedal to the floor!!! eastcoastGC8G Mid Atlantic Impreza Club -- MAIC 9 04-07-2010 02:12 PM
clutch pedal to the floor. throw out bearing? _wrxlr8r_ Transmission (AT/MT) & Driveline 13 05-31-2009 06:32 PM
Brake Pedal to the Floor Failure - Dealer says DOH! silenuskjh Brakes, Steering & Suspension 22 06-15-2001 09:24 AM
