Old 06-20-2005, 06:49 PM   #1
Genner
Member#: 18372
Default EDM STI lights leveling plugs
Where can you buy the connectors that go into the EDM STI headlight leveling harness? I believe it's the 6-pin connectors...
Genner is offline   Reply With Quote
Old 06-20-2005, 07:26 PM   #2
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
I am working on making levelling harnesses for the EDM STi lights... stay tuned
MK19_ is offline   Reply With Quote
Old 06-20-2005, 08:27 PM   #3
Genner
Member#: 18372
so where can you get them connectors that will fit the socket for the leveling socket on the EDMs units?
Old 06-20-2005, 11:35 PM   #4
prelude/2.5rs
Member#: 9355
2007 Infiniti FX35
2008 Mazda3 Hatch GT
Try wagons_ho. He made me a leveling harness for my Prodrive lights...with the EDM switch and all. He also has access to the AMP connectors which mate up to the leveling motors. Good luck!
Mike
prelude/2.5rs is offline   Reply With Quote
Old 06-21-2005, 01:38 PM   #5
wagons_ho!
Member#: 16574
I've been making levelling harnesses that mate to the factory plugs for the last couple of years. To do this yourself, be prepared to have several thousand of leftover pieces..... because of factory minimums required. To buy 10,you've got to buy a thousand plugs, 3000 retainers, 5000 terminals and 20,000 seals...
I also have the plugs that fit onto the switch.... add another 40,000 pieces there.
To do it my way, you don't cut anything, crimp anything. There's the factory plugs on the end of the harness that plug directly into your lights. If you have to change lights, there's no trying to find a plug or terminals to replace the ones you have to cut off using other methods to hook this up.
If you have EDMs or JDM HIDs, or 2004 HIDS, this is a proven and foolproof solution.
It was AMP connectors for the Prodrives - it's something more esoteric for the EDM levellers. I'm the only one other than Subaru and Nissan that have bought these connectors 8))).
wagons_ho! is offline   Reply With Quote
Old 06-21-2005, 01:50 PM   #6
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
PM'd you wagons_ho
lenyx is offline   Reply With Quote
Old 09-17-2005, 04:44 AM   #7
ChuckCheeze
Member#: 8143
2014 sti
WR Blue
Default pm'ed you wagon_ho!
pm sent
ChuckCheeze is offline   Reply With Quote
EDM STI headlights level switch Genner Electrical & Lighting 7 05-14-2004 05:44 AM
EDM STI headlight leveling problems (DZ) Electrical & Lighting 0 12-17-2003 04:19 PM
EDM STi lights!!! ImprezaBoy75 Alaskan Impreza Club Forum -- AKIC 15 05-10-2003 05:24 AM
Aiming EDM STI Lights Imitryx Electrical & Lighting 3 02-25-2003 05:53 PM
FS: EDM STi Lights... pro_ra1 Southern California Impreza Club Forum -- SCIC 1 01-27-2003 11:37 PM
