Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-20-2005, 11:51 PM   #1
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Default Baja T: Project Update
Well things are coming together:
Interior:
Boost Gauge
Installed this on fathers day. Picture is at idle and it goes to about 3 ticks past the .05 mark at full boost, equals 11.6 psi.
I connected to the dash lighting wire & a ground but the light does not adjust with the dash light, is that correct?
Recaro Seats
I am waiting on brackets from Recaro, hopefully this week
Performance
Suspension/Wheels
ION Performance springs are here, I am waiting on TireRack to deliver the GR2s
18" Forester STI wheels should be enroute
Exhaust
Xceleration TBE setup: suppose to ship out at the end of the week, I've got an extra turbo to downpipe gasket ready.
Not sure about the turbo, might do the VF39/TMIC from the STI for the full on Baja STI or possibly a different turbo. We'll see how the wife reacts after the exhaust and wheels arrive. I'd like to hit the dyno for before/after runs but not sure if I'll have a few hours during the week to mess around.
There is a Trackmasters event at Watkins Glen in early October, if I get the suspension sorted and possibly brakes, I may make the trip and see how the Baja feels on the track.
02_Forester is offline   Reply With Quote
Old 06-21-2005, 03:27 PM   #2
ez bturbo
Member#: 56048
2004 baja turbo 5spd
black/dark gray
i have the same boost gauge: i rarely more than two ticks past .05 (.07) ...sometimes in 5th i will see .075. I never noticed if it dimmed with the dash light, just that its white where the rest is green.
Rest looks great, im jealous!
ez bturbo is offline   Reply With Quote
Old 06-22-2005, 07:53 PM   #3
nurseman
Member#: 85518
Default boost gauge
how hard was it to install the boost gauge?
nurseman is offline   Reply With Quote
Old 06-22-2005, 09:07 PM   #4
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Very easy to install this one! If you can take apart a dash to install a radio, you are set.
Old 06-23-2005, 07:47 AM   #5
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
11.6psi? Is that stock pressure?
heehee you stole the pass, vent
Your Recaros are incredible!
Chris N is offline   Reply With Quote
Old 06-23-2005, 08:18 AM   #6
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
10.1 to 11.6psi range looks to be the my stock pressure -- the needle looked as if it has gone to .08 but it is probably maxed at .075
If the conversion to PSI is correct:
.07 = 10.1 psi
.075 = 10.8 psi
.08 = 11.6 psi
http://www.tiniusolsen.com/resource-center/mpa-psi.html
The GR2s finally arrived yesterday, now I need to find a place that will install and do an alignment without charging an arm and a leg.
Old 06-25-2005, 08:25 PM   #7
pgv
Member#: 73808
2003 Baja
Let us know how the GR2s do on your B. I am wondering about them myself.
pgv is offline   Reply With Quote
Old 06-28-2005, 12:05 PM   #8
iON Performance Inc
Vendor
Member#: 7673
02_Forester - So when's the tenative install date?
iON Performance Inc is offline   Reply With Quote
Old 06-28-2005, 03:17 PM   #9
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
july 8th is my appointment at Mach V's shop
hopefully I will be able to drive by then, since my right hand in now in a cast.
Old 07-01-2005, 03:20 PM   #10
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Tires are in and are getting mounted, I hope to have pictures tonight with the 18" Forester STI wheels.
Old 07-01-2005, 07:58 PM   #11
BoostedBaja
Member#: 87839
2005 Baja Turbo
Garnet Red Pearl
I'll bite and ask... Why is your hand in a cast?
[edit]
well... it was going well....I just got home from the ER.
while trying to push the rear muffler hanger off, I dislocated my thumb!! talk about a new kind of pain!
so, the exhaust is half off for the forseeable future. I need to get the stock exhaust bolted up by July 8th for my suspension install at Mach V's shop.
[/edit]
Oopsie, that sounds painful. I should look around and see if I have pictures from the micro-surgery I had on my had from smashing a glass. Needless to say the nerves in my finger have slowly been coming back to normal.
BoostedBaja is offline   Reply With Quote
Old 07-01-2005, 11:31 PM   #12
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
I should have snapped a picture but at the time I wasn't 100% sure if it was dislocated or broken and really didn't feel like posing
18" STI Rims are on. I can't wait to get the ION lowering springs on next Friday!! These picts are after just a few miles of driving, I think it will settle a tad more.
I went with a 225/45/18, stock size on the Forester STI and the speedo reads a hair fast. Turning at full lock there is no rubbing.
Old 07-13-2005, 04:39 AM   #13
DubuRX
Member#: 24307
05 Evo MR
AWD LUV
I'm looking at an 04 Baja Turbo, and I have a quick question. Do you know if the suspension is swappable with a WRX? I have what's left of the Tein basic coilovers from my wrecked WRX and I wonder if it'll straight swap or if I need an entirely new suspension.
Thanks!
DubuRX is offline   Reply With Quote
Old 07-13-2005, 07:57 AM   #14
KC
Member#: 442
16 SS
00 S2000
I doubt it. The Baja is built off the legacy/outback platform. You mihgt have a better time finding out if the WRX pieces fit on an outback and it'll most likely work with the Baja if it does.
--kC
KC is offline   Reply With Quote
Old 07-14-2005, 01:20 PM   #15
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
adding the OEM Baja seat belt clip to after market seat frame:
7/16" x 20 nut is needed to mount the seat belt clip bracket to the Wedge Engineering after market seat frame.
I got mine from Fairfax Auto Parts, they only had a Grade 5, I would have preferred Grade 8 but these nuts with the factory bolt should be ok in the event of an accident
Old 07-14-2005, 01:27 PM   #16
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
STI TMIC is on the way.
I need to track down a VF39 turbo to round out the STI conversion. Then it will be time for a little ECU tuning on the dyno.
Old 07-16-2005, 01:09 PM   #17
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
One in, one to go and some wiring:
and then once I resolve mounting the STI BOV I'll install the TMIC, just a little bigger
Old 07-18-2005, 06:42 PM   #18
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
that's what mine looks like too!! should put mine in on thursday or friday, whenever i can get some time off of work
cliffhanger is offline   Reply With Quote
Old 07-19-2005, 07:38 AM   #19
seenahyena
Member#: 91367
02_Forester - Your Baja is one Hot Beauty ! I have owned 2 red cars, but I wasn't keen on the red until now. It looks great.
I appreciate your tip on the Mach shop as I am in Fairfax myself.
I think if I got the red, I would consider putting on some gaudy gold 17 inch wheels. So my question is - you put 18's on, would that mean that 17 would definitely fit with no problem ?
seenahyena is offline   Reply With Quote
Old 07-19-2005, 09:26 AM   #20
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Yes, 17s are ideal -- Nelly has the '05 17" Outback XT on his Baja and there are a couple of others that have 17s also.
Old 07-19-2005, 09:38 AM   #21
KC
Member#: 442
16 SS
00 S2000
The seats.. do you sit any lower in the car?
Old 07-19-2005, 09:42 AM   #22
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
yes!! I finally have generous head room or I can raise it up to not have enough.
Definately enough room for a helmet now. ( I'm 6' 2" ) Its not that the stock seats or even the '04 WRX seats were too high, there were just tight for me and I wanted more room.
Old 07-19-2005, 08:36 PM   #23
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
just aquired a VF39 and a WRX BPV for the TMIC in another week the doc said my thumb will be back to "normal" just in time for me to mess up something else
Old 07-19-2005, 10:13 PM   #24
Bajapocket
Member#: 71690
2005 Baja Turbo
Those seats look GREAT! After a road trip from MD to KC over the Fourth of July weekend, I absolutely hate the stock seats - my a$$ still hurts! I've been eyeing Recaros for some time - I know you posted previously - but who did you end up ordering them from and how long did it take. Your Baja is really looking sharp!
Bajapocket is offline   Reply With Quote
Old 07-20-2005, 12:05 AM   #25
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
The vendor I ordered from has since lost the Recaro dealership. Swing by Recaro's website for the official list of vendors -- I ended up dealing directly with Recaro North America and they were fantastic. Speedware Motorsports is a Recaro dealer and they currently have a set of Recaro Speeds on their clearance page: http://www.speedwaremotorsports.com/specials/index.asp Those would look good in a Baja
In all honesty, if you don't need additional headroom and can find a set of '04 WRX or '05 WRX with heat, those would be my recommendation. I found my '04 WRX seats very comfortable and they fit me really well. Swing by the dealer and sit in a new WRX to get an idea, then contact some salvage yards or look in the NASIOC classifieds. The Recaros are definately great seats, the cooling feature really does work, if you have the budget, they are a fantastic option.
The particular seat bracket I got was a Sparco 400SB bracket made by Speedware Motorsports ( I just found this out today )
Baja STI project complete, great results!!! wikidwrx Baja Forum 63 01-07-2016 01:03 PM
'05 Baja-T: 193whp - 220ft/lbs 02_Forester Proven Power Bragging 7 10-28-2005 04:59 PM
'05 Baja-T: Dyno Results 02_Forester Baja Forum 4 10-27-2005 11:20 PM
Baja Project Update bajatuner Baja Forum 4 06-03-2005 06:03 PM
Udate on my Baja STI project, check it out! wikidwrx Baja Forum 21 04-03-2005 08:32 AM
