#1 |
Member#: 18372
Vehicle:2002 WRX White |
Is there any difference where you disconnect DRL?
In the engine bay or behind the glove box? Also one other question...which gives out better light output. EDM STI headlights or Morettes both with the same degree HID bulbs? thanks.
#2 |
Member#: 9355
NESIC
Vehicle:2007 Infiniti FX35 2008 Mazda3 Hatch GT |
When I had my stock lights on my wagon, I disconnected my DRL's under the hood. When I installed my Prodrive lights w/ HID, I then when the extra mile and disconnected it behind the glove box too. From what I hear, if you do not do it at the box, for some reason it will effect the HID's and will not work properly. It only takes a few minutes to disconnect at both points. Better safe than sorry. Good luck!
Mike |
#3 |
Member#: 16157
South East
Vehicle:'03 Mazda P5 <>< '02 WRX & '08 MS3 SOLD!!! |
The module in the engine bay is a dropping resistor, and it does not fully disable the DRL system. The plug next to the glove box is the main control module.
#4 |
Member#: 74588
NESIC
Vehicle:07 Camry XLE /08 Honda Pilot |
Glove box is uber easy to remove.........
#5 |
Member#: 410
Thanks for the pict, Hank.
#6 |
Member#: 25370
W. Canada
Vehicle:2003 WRX wagon Played Out Blue |
Glovebox. It only takes 2.5mins!
#7 |
Member#: 71881
i was planning to go for the Morettes since it seem to have better light output . but after seeing a few local subies with Morettes .seems to me the finish doesnt look to great . it got gaps between the light housing and the side fender . is it just the bad install ? or the light itself . can someone tell me
![]() Last edited by polarpreza; 09-28-2005 at 03:50 AM. |
#8 |
Member#: 16157
South East
I haven't come across the complaints that you mentioned with previous Morrette owners. I would be inclined to say that it was either a bad install or the individual's lights was damaged or not in good shape
![]() Many owners of the Morrettes do concur that the light output is superior to the stock setup. |
#9 |
Member#: 935
Vehicle:Tony Pond Fan Club |
The 02-03 Morettes were a lot better fit and finish wise than the 96-00 assemblies. But then you do get much better optics, even though the newer ones don't seem to use generic e-code lenses you could get anywhere.
#10 |
Member#: 29355
NWIC
Vehicle:2003 GD6 Hate chall but i'mma maintain |
glovebox is better because it is easily undoable and 'cleaner' way of disabling the circuit.
#11 | |
Member#: 6418
#12 |
Member#: 3894
Vehicle:2002 WRX Wagon Battlewagon Black |
If you just disconnect it under the hood, you'll have a floating plug with 12v still going to it. I wouldn't want this to get filled with debris, water, etc.
Disconnect it from behind the glovebox. It's super easy, and you don't even have to remove the glovebox. Just lay on your back in the passenger footwell, and lean your head back behind the glovebox. You can see the plug very easily if you have a flashlight. |
| Thread Tools | |
| Display Modes | |
| New STi: Dirty engine bay vs Simple Green | junk240sx | North West Impreza Club Forum -- NWIC | 10 | 02-24-2007 12:16 AM |
| Engine bay fuse box cover | Silver '02 REX | Private 'Wanted' Classifieds | 0 | 03-28-2006 07:56 PM |
| CF engine dress up kit and CF Glove box panel (NEW and cheap)... | MPREZYA | Private 'For Sale' Classifieds | 13 | 09-12-2004 10:05 PM |
| 01 fuse box cover in engine bay | M E R C U R Y | Private 'Wanted' Classifieds | 1 | 05-28-2004 10:59 AM |
