Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 06-21-2005, 06:05 AM   #1
SRpoweredS14
Member#: 33135
Default How to read CEL codes on a 96 Outback?
hi,
i'm posting for my friend, he has a 96 outback w/ a CEL, how do you check the codes? and does someone have a list of the codes? thanks
SRpoweredS14 is offline   Reply With Quote
Old 06-21-2005, 07:44 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The codes can only be read by plugging a scanner into the diagnostic port under the driver side dash. If you're in any state other than CA, Autozone does this for free, also you can ask for help in your local forum. Someone nearby probably has a scanner.
List of codes here, there are others that can be easily found by searching both this site and the web at large-
http://forums.nasioc.com/forums/showthread.php?t=298963
Reading CEL codes on a JDM ECU? powerlabs Subaru Conversions 21 03-19-2007 08:31 PM
UTEC to read cel codes? LiquidForce Engine Management & Tuning 0 05-14-2003 11:39 PM
How to check CEL code? AudioFan Normally Aspirated Powertrain 6 03-07-2003 11:30 PM
how to pull cel codes? no_rex_yet Service & Maintenance 3 01-17-2003 06:55 PM
How to read CEL code? MrZone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-08-2002 04:55 PM
