Old 06-21-2005, 05:58 AM   #1
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
Default optimal battery placement?
was wanting to relocate battery in the trunk, but also thought of relocating it to rear seat area or in the cabin somewhere. Wondering whats the best place to put the battery for optimal weight balance. thanks
petawabit is offline   Reply With Quote
Old 06-21-2005, 06:01 AM   #2
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
was thinking of a very small batter under the passenger seat since the battery need too much power(no radio, no power door locks or windows)
Old 06-21-2005, 07:52 AM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...like this....
...daily use since SEP03......made the front end feel much better, point better.
DOOOOOEEEEEEEETTTTTTT!!!!!!!!
Old 06-21-2005, 11:45 AM   #4
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
haha, yeah, you're placement gave me inspiration to put mine.I'm wondering if that's the best for weight distribution though.
Old 06-21-2005, 05:58 PM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....I guess you really didn't think about it much yet....or haven't studied much about polar moment of inertia or center of gravity.....or any of a host of other areas of vehicle dynamics....like I did........
....in essence.....lighter and lower, and closer to the center of gravity is best.....can't get any lower, and you could get the non-metal jacketed version of that battery and save another pound or 2....and it's a LOT closer to the center of gravity than under the hood or in the trunk....but that's about it.
Old 06-21-2005, 06:24 PM   #6
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
what kind of bag is that and how is it secured in place?
Old 06-21-2005, 09:26 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....that is a wallyworld special HD insulated lunchbox with plastic top/bottom that I got for ~$6.....and THAT was one of the hardest things to deceide on/find was what kind of box to put the damned thing in ....really......fits just about perfect under the seat.......friction fit ya know ......with the seat all the way back, there is NO WAY it is coming out without the seat coming out first....the grey connector is like the ones used for golf carts to charge them....~$15(silvered contacts ) and the cable is 4ga oxygen free power cable....the ground goes to the seat rail mount bolt and the POS goes up the center console----under the HVAC and out the firewall above the brake pedal to the POS in the underhood fusebox.....I left the cables under the hood in case I ahve to put a regular battery back there for some reason.....once I had all the parts/pieces in one place and the connectors soldered....the install took an afternoon and early evening....the whole thing is 100% fab'd....right down to the 24k gold plated bling tab I made to attach the ground to the seat rail bolt
Old 06-21-2005, 11:55 PM   #8
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
what the hell is wallyworld I think it'll be hard to friction fit the battery case since my seats can't slide all the way back(roll cage). thanks for the advice so far. now i need to compile all the parts i'm going to use.:-P
Old 06-22-2005, 04:39 PM   #9
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
wallyworld=Wal-Mart
khail19 is offline   Reply With Quote
Old 06-22-2005, 05:32 PM   #10
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
woops, I thought I posted it already. Is it called wallyworld is are you saying that wallyworld is equivalent to wal mart?
Old 06-22-2005, 07:46 PM   #11
tmeh
Member#: 30800
2000 .7 RS
no starter problems without a heavy ground line running to the motor??
thats kickass
tmeh is offline   Reply With Quote
Old 06-22-2005, 09:03 PM   #12
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
thats kickass
....nope....no electrical issues at all....ever......ya just can't leave anything electrical 'ON' with the engine 'off'. The Odyssey battery dosen't have any problem with being deep cycled or rapid charged/discharged, either...
......and the spot under the hood that was occupied by the battery makes a great place to put the water injection bottle and pump, too
Old 06-23-2005, 02:09 PM   #13
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
uncle scotty-would you be so kind to give me a break down of the things I'm going to need?
14ft of POS wire
10ft of neg?
terminals?
distribution block
quick connect switch
thanks for the help
Old 06-24-2005, 12:50 AM   #14
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
14ft of POS wire---hell no....less than 10
10ft of neg? ----More hell no...2 feet MAX
terminals? ----copper solder on 4ga ring terminals
distribution block ------hell no, use the underhood fusebox POS and just make a grounding kit
quick connect switch -----no....just the plug, an Anderson SB 120 http://www.andersonpower.com/products/mp/sb.html
thanks for the help
Old 06-24-2005, 01:37 AM   #15
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
mingnight pearl black
that crazy
tsubaru02 is offline   Reply With Quote
Old 06-24-2005, 02:25 AM   #16
veightkiller
Member#: 78967
2011 335i
Originally Posted by Uncle Scotty
...like this....
show us some pic's of your engine bay
veightkiller is offline   Reply With Quote
Old 06-24-2005, 02:36 AM   #17
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
thanks for the help uncle scotty. wondering though if if placed my battery where I placed yours, if it would be secure and pass tech. inspection at the track.thanks
Old 06-24-2005, 12:27 PM   #18
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....there is nothing there except the cable ends and cables for a 'regular' battery.....my catch can is attached to the front of the fusebox mount...
If you took your battery and the tray out, your would look just about the same as mine.
Old 06-24-2005, 12:30 PM   #19
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
.....there is an actual mount for that battery that would pass tech.....http://www.odysseybatteries.com/pc680hd.htm
These are VERY popular batteries for so many apps....must be some reason
That is FAA approved....so it better be good enough for whatever sanctioning body tech's your car
Old 06-24-2005, 01:39 PM   #20
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
very nice. which battery is lighter, the 680 or the 545?which would be the lightest battery that odyssey makes?thanks
Old 06-24-2005, 05:02 PM   #21
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I chose the 680MJ that has a metal jacket.....there is a non-MJ----no metal jacket version that would save ~2 pounds. the 545 would work, but I chose the 680 as a better daily use battery.
Read the below stuffff and see what ya think.
All the specs/styles/BS can be found here....http://www.odysseybatteries.com/specs.htm.....and here....http://www.odysseybatteries.com/files/techbook.pdf
Old 06-25-2005, 06:17 PM   #22
Eleazar
Member#: 68773
1993 Saturn
GOLDEN
What about this battery?
http://www.batterywholesale.com/batt...ml?prodID=3027
same specs, sort of a replacement for the PC680. It's half the price but I wonder if it would work as good in car (instead of motorcycle).
Eleazar is offline   Reply With Quote
Old 06-25-2005, 08:14 PM   #23
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....accept no substitute.....and you can find the Odyssey on ebay for only a couple $$ more than that price, and you KNOW it works, won't leak, and has a 3 year automotve use warranty...what more could ya want????
...don't be a cheap bastard
Optima Yellowtop battery placement NNJ_wrx Newbies & FAQs 12 06-15-2009 03:19 AM
a/f bung placement and egt probe placement 06whitesti General Community 2 11-12-2006 02:46 PM
('93-'01) What are the optimal shift points for saving gas? myko011 Impreza Forum 4 05-17-2001 12:36 AM
Optimal exhaust piping diameter for the WRX? cmb Factory 2.0L Turbo Powertrain 18 04-04-2001 06:49 PM
Message Board Statistics All times are GMT -4. The time now is 03:03 AM.
