Old 06-21-2005, 10:20 AM   #1
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
Default 15W 50 Mobil 1 too heavy for Sti
I was thinking of switching to a heavier grade because my car eats oil (no leaking) too 15W 50. Tuner suggested it, but dealership warned against it. Opinions?
essogas is offline   Reply With Quote
Old 06-21-2005, 10:55 AM   #2
rbahr
Member#: 40671
2006 STI, Outback XT
Grey, Blue
It is what I run in the summer in the NE area - but I do track the car a fair ammount so I think I need it. In the winter I run 0-40W
Ray
rbahr is offline   Reply With Quote
Old 06-21-2005, 11:56 AM   #3
Rdrcr
Member#: 83166
2005 WRX STi
Aspen White / Gold
There is not a lot of cold start-up protection with a 15w 50 oil.
Mike
Rdrcr is offline   Reply With Quote
Old 06-21-2005, 12:33 PM   #4
turbo2ner
Member#: 89385
many most all
WRB/blk/blk/blk/slvr/wht
Too thick bro. Your bearing clearence is what detemines the oil weight you should use. Unless you have had a motor built for that weight oil with a looser build then forget it. Maybe your motor is high milage, in that case your motor is now "loose". And a thicker oil should be used to restore the proper oil pressure. The thinner the oil, the more power. But you have to work with your engine builder on the over all plan for your application. Many different reasons for going one way or the other.
turbo2ner is offline   Reply With Quote
Old 06-21-2005, 01:12 PM   #5
GreenEJ25
Member#: 87574
I just got Motul 10w 40 and I drive in an extremely hot area. I was under the impression that because the oil is heavier it is more resistant to heat break down so I went with a little heavier oil for more protection. I'm probably an idiot though.
GreenEJ25 is offline   Reply With Quote
Old 06-21-2005, 01:48 PM   #6
AaronWRX
Member#: 7194
2011 997.2 Turbo
^^ i switched to German Castrol 0w30 for the summer!
it's holding up FAR better then mobile 1 5w30
AaronWRX is offline   Reply With Quote
Old 06-22-2005, 04:21 AM   #7
malibuda
Member#: 82152
here in the EU everybody uses 10w40 or 15w50
if you check out EU forums scoobynet(uk) nobody uses 0/5w30
i think that is the reason for useing to much oil
2 years and not a drop of oil i am useing motul v300 15w50 in the winter 10w40
malibuda is offline   Reply With Quote
Old 06-22-2005, 07:03 AM   #8
turbo2ner
Member#: 89385
many most all
So everybody ignores the owners manual, and common sense, and just put in whatever they feel is the best? Sounds good. Maybe try talking to a machine shop, or motor builder. See what they say.
Old 06-22-2005, 08:51 AM   #9
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
I don't know about your Owner's Manual, but my '05 STi manual mentions several different oil grades as being acceptable depending on ambient temps and how "hard" the car is used.
For the original poster: Try Mobil-1 5w-40, should work well in your STi.
AndyH is offline   Reply With Quote
Old 06-22-2005, 09:15 AM   #10
bluesubie
Member#: 767
04 FXT
Apparently everyone just looks at the oil cap instead of RTFM.
essogas - 15W50 might be too thick for Canada and your needs. If you're trying to stop your car from using oil, increase the thickness gradually IMO (0W40, 5W40). Keep in mind that you still might use oil for the first few thousand miles if you switch brands.
-Dennis
Old 06-22-2005, 10:18 AM   #11
rbahr
Member#: 40671
Grey, Blue
The owners manual does NOT include operating the car at a race track or supporting sustained oil temps of >250 deg F. Oil like gas is one of those subject matters that is surrounded by lore and urban legend.
A site that I like is http://www.bobistheoilguy.com/ for information. In addition Mobil, Redline and others are a good source of real information.
Ray
Old 06-22-2005, 12:27 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....the ONLY reason that 5w30 is 'recommended' is for CAFE....it saves a bit of gas........NOT because it is 'good' to use or good for the engine in any way.
There are a LOT of myths in this community and the 5w30 one is one of the most idiotic out there.....
Old 06-22-2005, 03:18 PM   #13
AaronWRX
Member#: 7194
2011 997.2 Turbo
I put GC 0w30 in my car because it's green, and it's made my little green elves.... not just because it felt right. sheesh!
Old 06-23-2005, 09:33 AM   #14
bluesubie
Member#: 767
04 FXT
Not for long.
-Dennis
FS: DFW 10 quarts of 15-50 Mobil 1 bape-ape TXIC Private Classifieds 0 08-19-2008 09:57 AM
Prodrive STI knob too heavy for me-options??? MrBlonde Interior & Exterior Modification 10 10-13-2005 08:51 PM
Eibach 04 Springs too soft for STi glilly Brakes, Steering & Suspension 26 04-16-2004 04:30 PM
Too Pricy for Sti? YaB Alaskan Impreza Club Forum -- AKIC 2 07-11-2003 08:47 PM
15W-50 Mobile 1? Gerlando Bay Area Impreza Club Forum -- BAIC 2 04-24-2002 05:16 PM
