Old 06-21-2005, 11:57 AM   #1
Bakergtt
Member#: 59207
'05 X was 98 LGTT
Default Pop!!!! Clank Clank Clank :-(
yeah so.............yesterday..........1 in the afternoon......just taking off from a light, and no i wasnt rocketing off from a stop.......shift into 2nd gear and POP!!!!!!!!!! clank clank clank............***!!!!!!!!! im figuring the throw out bearing in the clutch, since its been making noises but yeah something popped yesterday and now i cant shift the car. just wants to stay in neutral and if i try letting out the clutch.....CLANk CLANK CLANK!!!!!!!!!!!!
Bakergtt is offline   Reply With Quote
Old 06-21-2005, 11:59 AM   #2
Bakergtt
Member#: 59207
'05 X was 98 LGTT
http://rallitek.net/forums/showthrea...8083#post18083 more here but yeah Well......the guys pulled out the tranny yesterday and yeah.......as Ahaugland stated "check for chunks" well there were chunks. 2nd gear toasted. i figured what caused it to go was a couple of hard shifts tending to go to 4th I hit 2nd.
Well the guys at Rallitek are always there for me and jumped right away at it and looks like im going to get a rex tranny Thanks again to Brydon, Kelly, and Joel. You guys ROCK!!!! and I would always trust you three to do any work to any car I ever own.
Hope fully i can find my camera and i will get pics of everything even the gear trashed.
Old 06-21-2005, 01:13 PM   #3
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
that sucks, good luck with the next tranny. i recommend a RA gearset or maybe one of the newer FXT trannies with 4.44
or just six speed and no more worries
also could you post the pics here and not on rallitek's forum.
Ben
Old 06-21-2005, 02:17 PM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
No kidding, I wouldn’t waste my time with a regular rex 5MT (got one now), plus you’ll have to change gear ratios or put your old R&P in. Try to find the larger Forester 5-speed or throw some RA gears in a rex tranny before installation.
Also other notes, if you do go rex DO NOT get an 05’ rex tranny or you’ll have to deal with different shafts and seals (again, like I did ). Also your existing VSS will bolt right up no problems, although I think the other connectors may need to be rewired...
Good luck man…
xcntrk75 is offline   Reply With Quote
Old 06-21-2005, 03:13 PM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
yea gruppe-S has FXT trannies with rear diff for 2k, which is a great deal and a smart way to go IMO.
Ben
Old 06-21-2005, 08:42 PM   #6
Bakergtt
Member#: 59207
'05 X was 98 LGTT
well find me a 6mt for 2k and i will
Old 06-22-2005, 11:33 AM   #7
PHATsuby
Member#: 13617
2001 Legacy GT back
if you find a 6mt for 2k let ME know
Ben
Old 06-22-2005, 12:12 PM   #8
Bakergtt
Member#: 59207
'05 X was 98 LGTT
I cant have my car down long cuz i depend on it a bunch. I got lucky and a rex 5mt it there and its cheap (800). yeah they have to change things around a little but i am also getting a free diff from a friends (thanks matt) so i cani really beat whats there already with out going throught the hassle of finding something else. the ratio is lower so the top end of the car will be faster :-)
Adam (Rio)
Old 06-22-2005, 12:13 PM   #9
Teh Legacy
Member#: 9853
to keep your mouth
shut.
There's one thing about the RA gearsets I don't like, and that's how short the gears are. In 5th gear at 80, which we all know is a normal cruising speed, you're revving out to almost 5k. That's ridiculous. If I were you, I'd get a normal STi 5 speed. They're just as strong, but they have more realistic gear ratio.
/Jonathan
Teh Legacy is offline   Reply With Quote
Old 06-22-2005, 01:11 PM   #10
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
That's why most people just use the RA 1-4 gears and keep the OEM 5th...
Old 06-22-2005, 02:12 PM   #11
Bakergtt
Member#: 59207
'05 X was 98 LGTT
/Jonathan
I would love an STI tranny but to get one quick is very hard to do.
Old 06-22-2005, 02:53 PM   #12
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Try Lachute Subaru (www.lachuteperformance.com). They seem to be able to find parts like this fairly quick and easy.
/Jonathan
Old 06-22-2005, 08:04 PM   #13
Bakergtt
Member#: 59207
'05 X was 98 LGTT
Default Pics
Here is whats left of 2nd gear:
And here is the crap in the bottom of the case
Old 06-23-2005, 02:16 AM   #14
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
That sucks.
RA gearset would be great with your setup. my car= 80mph 4,500 rpm. Awesome acceleration. I would reccomend getting the RA and putting in a normal wrx 5th. Good luck
Tizzle is offline   Reply With Quote
Old 06-23-2005, 11:16 AM   #15
Bakergtt
Member#: 59207
'05 X was 98 LGTT
WOW!!!! all I can say is the guys at Rallitek can turn things around quick!!! Started on monday and I got it back Last night. New tranny (wrx sorry guys), new wrx clutch and flywheel and a new wrx diff with pos which I didnt have before.
Not use to the clutch or the time it takes to get up to speed but im sure I will. These gears are long!!!!! I can get up to 60 in 2nd. I just need to get a lighten fly wheel now so it revs quicker.
Thanks again to the guys at Rallitek
Adam (Rio)
Old 06-24-2005, 03:16 AM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Due to the larger differences in gear ratios, using an RA 3rd/4th & stock WRX 5th often results in a grind shifting from 4th - 5th. Not in all cars, but frequently enough we do not recommend this setup.
If you're looking to retain the 5th gear, I would suggest the STI RA Special Edition gears, which have a slightly higher gear ratio and is able to retain the WRX 5th.
I personally have this in my 04 WRX (310whp) and the ratios are still great, helps to spool larger turbos.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 06-24-2005, 06:59 AM   #17
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Adam (Rio)
Glad you’re happy with it Adam..! The added LSD is a huge benefit over your original open diff, it really helps to keep the rear-end in line under heavy cornering. Yes the WRX gears are super long-legged. When my EJ20 was in a more stock form I would close the 1/4 mile at the top of 3rd gear. Now I have to shift into fourth but still that’s 100mph in the middle of 4th gear.
Old 06-24-2005, 01:17 PM   #18
Bakergtt
Member#: 59207
'05 X was 98 LGTT
Yeah talk about long. i hit 110 in fourth and still had room to go and and all of 5th I am also loving how it kicks in hard in 3rd and just goes and goes.....sweat (kip voice)
popping kinda clank sound....... jmoney2648 Brakes, Steering & Suspension 10 10-28-2008 05:15 PM
Loud POP and then clanking noise ever12 Service & Maintenance 5 07-19-2008 01:56 AM
Holy ****e I fixed the CLANK CLANK CLANK !!! Triton05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-24-2005 09:33 AM
Bang...clank clank clank 2002WRXSTi Proven Power Bragging 8 06-10-2004 09:13 AM
Big problem - clanking, popping, grinding, etc wlchan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-18-2004 06:12 PM
