Old 06-21-2005, 02:38 PM   #1
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Default Battery Relocation?
So I have the need to relocate my battery to the trunk to accommodate some upcoming mods. Who's done it and what all is involved?
How much of a pain in the ass is it?
What gauge wire did you use?
Did you install a disconnect?
What about a large inline fuse?
Did you run the wires inside the passenger compartment or along the undercarriage?
xcntrk75 is offline   Reply With Quote
Old 06-21-2005, 03:10 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
http://rallitek.net/forums/showthrea...hlight=BATTERY
PAGE 7, POST #66
That is RiosubaGT on this board. Probably relocated it for the same reasons you will be.
Jared
gtwagon941 is offline   Reply With Quote
Old 06-21-2005, 03:11 PM   #3
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
i suspect a FMIC coming....
Ben
Old 06-21-2005, 06:49 PM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
BettAr.... I need the room for a water tank
Old 06-21-2005, 08:27 PM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I would use two large fuses, the first about a foot away from the actual battery and the second where the OEM wire meets the wire that will run to the trunk. Donít go with a fuse that is too big because it wonít do any good. I think when I looked into doing this I was looking at fuses in the 100 to 120 range.
subiekid is offline   Reply With Quote
Old 06-21-2005, 08:34 PM   #6
Bakergtt
Member#: 59207
'05 X was 98 LGTT
Its not too bad really. just takes time. I used 2awg wire. What do you mean a disconnect? I have two inline fuses of a 100 amps. one at battery connector and one at the fused junction box it runs too. i ran it inside just like an amp power cable. under all the carpet and seats.
Bakergtt is offline   Reply With Quote
Old 06-21-2005, 08:55 PM   #7
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Thanks for the feedback allÖ
Some tracks/strips require a battery quick disconnect when the batts been relocated from the factory location. Basically a high-amp switch like THIS
Old 06-22-2005, 12:15 PM   #8
Bakergtt
Member#: 59207
'05 X was 98 LGTT
I see no reason to have that disconnect. if you have a fuse at least at the battery connector you should be safe. if that line shorts anywhere the fuse at teh connector will blow and cut power at the battery.
Old 06-22-2005, 02:17 PM   #9
Bakergtt
Member#: 59207
'05 X was 98 LGTT
Here is the bettery connector i am using on the positive
and the neg
Old 06-22-2005, 02:29 PM   #10
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Oh I see...with the integrated fuse, those are sweet. I imagine they can be found at any performance audio shop?
Old 06-22-2005, 03:41 PM   #11
Bakergtt
Member#: 59207
'05 X was 98 LGTT
You should as long as they carry streetwire. if they dont have any in im sure they can order them. they arent cheap, like $30 - $40 for one
Battery relocation, with conventional Battery. azn0boi04 Electrical & Lighting 3 02-23-2010 11:06 PM
Battery Relocation Kits BongMan Normally Aspirated Powertrain 25 09-16-2001 01:29 AM
('93-'01) Battery relocation questions Imprezer Impreza Forum 2 06-05-2001 04:50 AM
For sale: battery relocation kit bill harvey New England Impreza Club Forum -- NESIC 3 03-04-2001 03:39 PM
Battery Relocation? Jeff 2.5RS Newbies & FAQs 2 10-16-2000 09:58 AM
