Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 06-21-2005, 04:06 PM   #1
figgskzoo
Member#: 82547
2010 Forester
Default Fuel Pressure test and Regulator location
Where is the fpr on a '97 OBS 2.2 n/a?
Does anyone know of a source of info on testing my fuel pressure?
I promise I searched before I posted a new thread -- please don't flame
Thanks
figgskzoo is offline   Reply With Quote
Old 06-21-2005, 05:59 PM   #2
abosworth
Member#: 53856
2003 WRX
Stage 2 taxi
Thanks
It should be on the near the left side of the intake manifold. It is at the end of the fuel rail and near spark plug #3. It is a metal peice with one rubber hose and one metal hose connected to it. That's where it is on my car anyway.
abosworth is offline   Reply With Quote
Old 06-22-2005, 04:38 PM   #3
figgskzoo
Member#: 82547
2010 Forester
Default thanks!
Thanks! I'll take a look for it.
Any idea how to test fuel pressure in my little 2.2 n/a?
Old 06-23-2005, 10:36 AM   #4
abosworth
Member#: 53856
2003 WRX
Stage 2 taxi
All you need is a T fitting guage. Just disconect the fuel line from the fuel filter and connect it between the fuel filter and the fuel rail. I have a legacy 2.2 n/a and the pressure should be between 34 and 40 psi. I can't imagine that your engine would be any different although i could be wrong. To test if the FPR is bad you should disconnect the hose from the FPR and the pressure should rise to (38-44psi). If that is not the pressure you are seeing than your FPR is bad. You might want to relieve the fuel pressure before you connect the T fitting. Locate the fuel pump and disconnect the the electrical connector. then turn your car on and allow it to die. then the pressure will be relieved. You don't have to do this it just depends if you care about getting some gas on your hands .
good luck
Old 06-24-2005, 03:30 PM   #5
figgskzoo
Member#: 82547
2010 Forester
Many thanks abosworth...I'm planning on doing this and wheel bearing this weekend.
I'm rolling thru VT in early August...I'll stay in touch, and if I'm nearby, I'll buy you a beer!
Old 06-24-2005, 05:35 PM   #6
abosworth
Member#: 53856
2003 WRX
Stage 2 taxi
NO problem, glad i could help Did you find the Fuel Pressure Regulator?
Old 06-29-2005, 09:42 AM   #7
figgskzoo
Member#: 82547
2010 Forester
Default found the fpr
Now to perform the actual tests. I'll be dong those next week as I'll be out of town this weekend and I'm feeling desperately lazy in this 90+ degrees and humidity in the Great Lakes region.
Fuel pressure test instructions? pwrx Service & Maintenance 1 09-05-2007 10:20 PM
Did intake pressure test and... fastwrx05 Factory 2.0L Turbo Powertrain 14 05-08-2007 06:12 PM
Fuel Pressure Questions and Sneezing jeffsnyder Normally Aspirated with bolt-on Forced Induction Powertrain 2 09-02-2003 05:31 AM
locating fuel pressure regulator wrxmontao!! Factory 2.0L Turbo Powertrain 6 10-07-2002 09:40 PM
Weapon R Fuel Pressure Riser and Icon skywalker Bay Area Impreza Club Forum -- BAIC 0 08-21-2000 03:55 PM
Message Board Statistics All times are GMT -4. The time now is 02:59 AM.
