Old 06-21-2005, 04:33 PM   #1
salem
Member#: 56143
Fit is Go
Default Electrical gurus- Perplexing problem
I'm installing jdms using a pnp wiring harness (not vampire taps) and silverstar bulbs. Ok, the problem:
Got everything hooked up, checked out the lights:
*driver's side worked perfectly
*passenger side low beams didn't work. High beams weren't very bright.
We thought we had a bulb problem, so we swapped driver and passenger side bulbs (both high and low) to check. However, we got the same result as above. It's not the bulbs.
We then thought it was the harness. We took them off and swapped sides, the result:
*driver's side low beams didn't work. High beams weren't very bright.
*passenger side worked perfectly.
*the exact opposite as above!
We therefore thought the problem was with the harness, but when we did a continuity test on the harness wires, they both worked.
We have plugged them tightly in, everything seems hooked up....we're stuck!
What else is there to check?
salem is offline   Reply With Quote
Old 06-21-2005, 05:00 PM   #2
salem
Member#: 56143
Fit is Go
I figured it out- the pnp harness needs to be jiggled to make a good connection. Now I have to figure a way to make it stay connected.
Old 06-21-2005, 05:51 PM   #3
ieiscooby
Member#: 38258
2004 EWG VF30 WRX
cut the wires and solder them on
ieiscooby is offline   Reply With Quote
OT electrical gurus - school me on electricity -=C=- Off-Topic 37 12-31-2014 02:17 AM
? for electrical gurus burgers Electrical & Lighting 2 03-16-2004 09:21 PM
Electrical Gurus! RotarFreak Interior & Exterior Modification 5 08-16-2001 12:15 AM
Electrical gurus, please help!! Dozza Interior & Exterior Modification 16 08-13-2001 10:44 PM
