Old 06-21-2005, 06:13 PM   #1
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Default Different battery size than OEM okay?
I just traded my WRX in for a LGT and I kept my Optima Group 35 battery. Can I put it in the LGT even though the LGT has a Group 85 battery?
wrx05 is offline   Reply With Quote
Old 06-22-2005, 06:43 AM   #2
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
anyone?
Old 06-22-2005, 06:55 AM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
It will work, but why change out a good battery?
speedyHAM is offline   Reply With Quote
Old 06-22-2005, 07:07 AM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
if you can secure it in place ok, then you should be fine. As far as the car is concerned, a 12V battery is a 12V battery.
Old 06-22-2005, 05:36 PM   #5
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Thanks DRD thats what I figured.
Im switching out the stock for an almost new Optima Red Top. Those extra 350 CCA's will come in handy this winter.
Old 06-23-2005, 02:41 PM   #6
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Well, the Red Top fit perfectly. Seems to be just a bit smaller than the 85. All the cables and the bracket fit fine. Thanks for the input!
Old 06-23-2005, 04:11 PM   #7
one wicked wrx
Member#: 27017
07 WRX
i use a civic DIEHARD battery lets me change spark plugs without pulling the battery and better fit with my fmic
one wicked wrx is offline   Reply With Quote
Old 06-27-2005, 02:45 PM   #8
speedblind
Member#: 42202
I was thinking of going to a smaller battery as well - do you have subs/amps in the car? Any problems with the setup so far?
speedblind is offline   Reply With Quote
Old 06-28-2005, 06:56 PM   #9
TreyS
Member#: 42478
2004 WRX STi
White/Gold
I'm using this 13 pound one in my STi and it's worked great with a removable Sub for almost 1.5 years now. Screw Braille.
I got it from here for $65 plus $10 for the terminals:
http://www.portablepower.com/items/b...SL105/37L105S1
TreyS is offline   Reply With Quote
Old 06-28-2005, 08:14 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
PRODUCT NOTES
For motorsports applications use the Odyssey battery. The Odyssey was designed for rugged vibration sensitive applications with thicker plates to prevent cracking and premature failure. The warranty on the Genesis doesn't cover motorsports installations.
http://www.portablepower.com/product...es/Odyssey.asp
Old 06-28-2005, 10:52 PM   #11
speedblind
Member#: 42202
Ah, good stuff. Thanks for the links and the info. It will be nice to have some room on that side of the engine bay - tired of removing the battery to change plugs!
Old 06-29-2005, 08:53 AM   #12
ardinos
Member#: 61590
2005 WRX STI
Grey
Anyone have experience with winter and this battery in the car:
http://www.portablepower.com/items/b...SL170/37L170S1
ardinos is offline   Reply With Quote
Old 06-29-2005, 08:57 AM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
IMO if you live in an area that gets cold winter weather, a lightweight battery is not a good idea. Cold temps+low reserve capacity=bad.
Old 06-29-2005, 09:29 AM   #14
ardinos
Member#: 61590
2005 WRX STI
Grey
That's kind of what I figured, but I was hoping someone had tried it with great success.
Old 06-29-2005, 04:34 PM   #15
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Who drives at the track in the winter.
Keep the OEM one for winter use, and the light one for summer.
Here is the other one if you are worried abut motorsports use and cracking plates (My Hawker is fine and I beat on it pretty hard):
http://www.portablepower.com/items/b...SL105/37L105S5
Old 06-29-2005, 07:01 PM   #16
speedblind
Member#: 42202
This is looking better and better. Trey - do you have a pic of the battery installed in your STi? What did you do for a tie-down? I saw this link on the site you posted, and it seems like it would be fairly easy to fabricate something similar:
http://www.portablepower.com/items/s...1/all/30Z680A1
My main goal is to have easy access to the plugs for changing and compression tests, as well as a little more room for my HID ballasts. Weight savings is just a bonus.
Old 06-30-2005, 10:41 PM   #17
subic
Member#: 87788
Anybody brave enough to use these during the winter though?
subic is offline   Reply With Quote
Old 07-02-2005, 10:26 AM   #18
Diode663
Member#: 70325
03 Wrx Sedan
WTB Rear Lateral Links
im sure it cant be too bad in the winter. I just bought one and its going under my passenger seat. So it should be at least a little sheltered from the cold. But we will have to wait until winter to find out for sure.
Diode663 is offline   Reply With Quote
Old 07-02-2005, 12:27 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
...ya might wanna do what I did and keep the stock cables under the hood just in case ya gotta put a regular battery in it
....mine has worked well down to ~25F, and it helps to turn the key---wait 'til the fp pressures the fuel system....~3 seconds----and then start the car
Old 07-03-2005, 04:54 PM   #20
Diode663
Member#: 70325
03 Wrx Sedan
Thanks for the advice. I was planning on keeping the cables in the stock locations incase anything went down.
Old 07-05-2005, 06:34 PM   #21
Diode663
Member#: 70325
03 Wrx Sedan
Uncle scotty would you mind snapping a picture of where you hooked up the positive to under the hood? Your help would be appretiated.
Old 07-10-2005, 10:02 PM   #22
Diode663
Member#: 70325
03 Wrx Sedan
bump for some help.
Old 07-10-2005, 10:25 PM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
....sorry---didn't see this again until now.
....follow the POS battery cable up under the fusebox under the hood-----where it attaches to the terminal, there......at first, I just took the cable end where it attaches to the stock battery nut off and bolted it to that, but it was 'messy' that way.
...sorry....borked my camera cable...no pics
Old 07-10-2005, 10:29 PM   #24
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No excuse- get a card reader-
Old 07-10-2005, 11:05 PM   #25
ERXWRX
Member#: 91000
Yep you can go smaller with no ill effects.
59r is a small Honda Civic Battery, but you want to look for a Miata battery for real weight savings
ERXWRX is offline   Reply With Quote
optima battery size question nation1979 Newbies & FAQs 0 06-14-2009 05:06 PM
iTunes Error - Showing Different Size Than My IPod OriginalSin Off-Topic 0 09-12-2006 09:56 AM
Optima battery size help andjurs Electrical & Lighting 5 12-18-2005 07:13 AM
good replacement battery (other than optima) raven Service & Maintenance 10 10-21-2003 01:20 PM
Speedo differences with different tire sizes? wcbjr Brakes, Steering & Suspension 11 03-15-2001 07:24 AM
