Old 06-21-2005, 06:47 PM   #1
jasper
Guest
Member#:
Default gasket question
I was just playing around with my Stromung Type XA catback that I ordered from boxer4racing.com a while ago and noticed something wierd with the gasket that goes on the end of the mid-pipe closest to the headers/cat. The gasket doesn't line up perfectly with the bolt holes or the pipe for that matter. Its close, but not quite perfect. Is this going to be a problem? Is this the right gasket and if not, where can I get the right one?
-D
Old 06-21-2005, 06:52 PM   #2
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
pic plz that will help us
impr25rs is offline   Reply With Quote
Old 06-21-2005, 06:57 PM   #3
jasper
Guest
Member#:
sorry. i don't have a digital camera. I'll try to borrow one though.
Old 06-22-2005, 02:22 AM   #4
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Do you mean it fits, but has a little overhang in the pipe? Or it's so close to fitting that it's the right design, it's just a little off?
If so that'll be fine. Trim away the overhang material in the pipe if you like to make it flow a little better, but it'll work fine even if you don't
jasona is offline   Reply With Quote
Old 06-22-2005, 03:32 PM   #5
jasper
Guest
Member#:
no. its the other way around. the gasket doesn't cover the whole pipe.
Old 06-22-2005, 04:13 PM   #6
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Sounds like you got a mismanufactured gasket. Buy some gasket material and cut yourself one that matches the flange or go and buy one of those spiffy ones that Subaru specs. I've got homemade ones and it's never once leaked.
Al_Smokemcrack is offline   Reply With Quote
Old 06-22-2005, 04:26 PM   #7
jasper
Guest
Member#:
would a place like autozone carry this gasket material or where would you suggest getting that?
-D
Uppipe Install: Gasket Question NewSuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-12-2002 05:18 PM
Head Gasket Question bgd scooby Normally Aspirated with bolt-on Forced Induction Powertrain 0 02-13-2002 06:08 PM
Up-pipe gasket question... mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-22-2002 02:55 AM
Pat Olsen - head gasket question once again. 2.5GT Normally Aspirated Powertrain 1 11-16-2001 01:32 PM
Newbie gasketing question the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 7 08-01-2001 03:00 PM
