Mid Atlantic Impreza Club
Old 06-21-2005, 06:52 PM   #1
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
Default UTEC Check Engine Light
I have a question for you guys.... I will be buying a STI soon hopefully and down the road I will want a UTEC. Will the UTEC get rid of any CEL's from putting on a catless turbo back? I'm just worried about Maryland emissions. They just plug into your OBD11 port now and scan for CEL's. Thanks..
Paintballguy is offline   Reply With Quote
Old 06-21-2005, 07:13 PM   #2
wrex03
Member#: 29963
04 sti
yes and no. You can turn off the cel on the dash, but the cruise light will flash and will be none functional.
wrex03 is offline   Reply With Quote
Old 06-21-2005, 08:44 PM   #3
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
The UTEC won't help you pass emissions. The UTEC's only OBD-II related function is to turn off the light itself on the dash. The code is still there and will be read by the VEIP. As wrex said, it will also still cause the Cruise light to flash if you end up throwing the code.
However, you can just use the mechanical CEL fix (basically a small extension for the rear O2 sensor) and you shouldn't have any issues.
serendipity is offline   Reply With Quote
Old 06-21-2005, 09:37 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ALL the normally associated CEL's are VERY easily to deal with....AND pass an OBDII test.....the UTEC won't matter for the test, and isn't curative for the CEL(s).
Old 06-21-2005, 09:52 PM   #5
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
ok, thats all I needed to know. Thanks for the help.
Old 06-22-2005, 10:37 AM   #6
essteaeye
Member#: 88086
05 STi
Black on Gold
yes i got the mechanical CEL fix (the extension thing) and so far so good. Ill drive around for another few hundred miles and ill let you know if it comes on! So far I love the Stage 2
essteaeye is offline   Reply With Quote
Old 06-22-2005, 12:32 PM   #7
kts262
Member#: 45464
91 E30 325i
95 E36 325is
yep just get the Mechanical fix and you're golden. You can search on here for the DIY mod or if you don't have a workbench and vise to drill and do the DIY once you can get the Helix mechanical fix from Gruppe-S for like $13. I bought the Helix one when I was getting some other parts from there and it's very nice, screwed right into my TurboXS downpipe.
kts262 is offline   Reply With Quote
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
check engine light comes on and i have utec family wRXagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-28-2009 01:38 AM
UTEC Check Engine Light V8killah91 Engine Management & Tuning 8 11-27-2005 06:28 PM
does utec block check engine lights gsteclipse33 Engine Management & Tuning 5 01-12-2005 12:18 PM
wierd utec prob.. check engine light on when i disabled it topgrinder Engine Management & Tuning 2 03-14-2003 04:51 AM
