Closed Thread
Old 06-22-2005, 02:02 AM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default Dash light short? ..troubleshooting
Not too long ago I replaced my stock boost gauge with another one. The new one has multiple colors (LEDs), so it requires an "always on" 12V source to remember your color preference. The stock boost gauge of course has the vacuum tube, black ground wire, and yellow accessory power wire. I ran the constant 12V from the fuse box. Everything was fine until today. I pulled the gauge out of the pod to make sure that the vacuum tube was still properly fitted. In the process I manged to short two wires together due to a crappy tape job.
My dash lights are no longer working. My clock is out. My head unit (not stock) has partial illumination but will not turn on. No fuses are burnt out under the dash nor under the hood. I pulled out the continuity tester and I can get +voltage on all three wires ( 12v, ACC, and ground) at the boost gauge when the ignition is on. When the car is off, only the 12v constant source shows voltage.
For the hell of it, When the car was off, I applied the constant voltage to the accessory wire, which illuminated the dash. I applied the 12v to what used to be the ground and the parking lights came on.
I take it something is fried together somewhere along the way?
TyranosaurusWRX is offline
Old 06-22-2005, 09:36 AM   #2
2phless
Member#: 69343
2000 nothing good
slow
The subaru dash illumination wire uses a 12v when the parking lights are on and a variable resistance for the ground side to dim the panel. That stuff is sensitive and you've probably popped the dimmer.
2phless is offline
Old 06-22-2005, 11:31 AM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
As in the switch itself? If so, do you know where that is located? I am assuming near the turn-signal arm....
Old 06-22-2005, 03:49 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Not the switch, you probably blew the illumination control module.
Mulder is offline
Old 06-22-2005, 04:26 PM   #5
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Hmmmm, sounds serious.......
Old 06-23-2005, 01:39 AM   #6
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Any idea where this module is on an 02 wrx?
Old 11-03-2007, 10:44 AM   #7
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Just to update this, if anyone ever comes across this post I would like to add a link to what I found. Finally got around to messing with this.....
http://forums.nasioc.com/forums/show....php?t=1374998
Closed Thread
dash lights and tail lights quit working jasona Electrical & Lighting 3 03-21-2006 10:22 PM
Dash lights and Light pods?? 3BadHabbits Electrical & Lighting 4 11-06-2003 12:36 AM
NO dash lights and climate control lights blkbdrx Electrical & Lighting 4 10-24-2003 10:09 PM
What wire do I tap to make a neon light go on when I turn my dash lights on? NewbyScooby Electrical & Lighting 2 03-27-2003 07:44 PM
Message Board Statistics All times are GMT -4. The time now is 05:34 PM.
