Old 06-22-2005, 06:23 AM   #1
donut
Member#: 9957
Default Blown Headgasket #2
OK guys i need a manual to show me the way through replacing my headgaskets.i have seen copper headgaskets online some where but now i can't find them and are they worthit? and if anybody has any tips please let me know
thanks Matt
donut is offline   Reply With Quote
Old 06-23-2005, 12:50 AM   #2
donut
Member#: 9957
Has anyone out there done a headgasket job themselves? wut about all you scooby specialists ?no one can throw me a bone here ow ya bump
Old 06-23-2005, 05:12 PM   #3
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
from what I've read copper gaskets leak like crazy. Go with steel.
jasona is offline   Reply With Quote
Old 06-23-2005, 07:55 PM   #4
Lavery
Member#: 77896
98 impreza 2.5rs
Here's some links that should help you get started. There's some good info in all of them if you click around a little. Never done one myself, but it is very "do-able" from what I've heard.
http://users.sisna.com/ignatius/subaru/headgasket.html
http://home.comcast.net/~skipnospam/...placement.html
http://wac.addr.com/auto/obs/headgasket/headgasket.html
Lavery is offline   Reply With Quote
Old 06-24-2005, 02:13 AM   #5
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
mingnight pearl black
dam head gasket on those rs suck huh
tsubaru02 is offline   Reply With Quote
Old 06-24-2005, 03:51 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Based on the subject I assume you've blown the head gaskets before? How long ago, and who fixed it the first time? If it was the dealer, they should have a 1 year, unlimited mileage warranty on the part. Since the part(s) failed, it would be replaced under warranty.
Mine failed the first time at ~59,500 miles (lucky ) so they were replaced under the original powertrain warranty. Less than a year later, with about 77,000 miles on the car, the gaskets went again and were replaced again at no cost to me.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 06-24-2005, 06:22 AM   #7
donut
Member#: 9957
Default Thanks
Hey Pat
we talked before about my headgasket blowing right after my warranty expired and now its blow sky high. i stop at advanced auto and a whole gasket kit from felpro ran about $250 but i want a heavy duty non blowing headgasket. thanks for the help guys
Old 06-24-2005, 09:09 AM   #8
Hayes
Member#: 11808
Two sets of blown head gaskets?? Was the heads AND block where the heads seat skined and made perfectly flat before gasket were installed?? The factory HGs have been redesigned so were you getting the latest and greatest?
Hayes is offline   Reply With Quote
Old 06-24-2005, 09:56 AM   #9
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Yup. I'd double check that the heads are within the service manual's limits, and that you are getting the newest (these should be 4-layer) head gaskets from Subaru.
jamesfacts is offline   Reply With Quote
Old 06-24-2005, 11:22 AM   #10
donut
Member#: 9957
the first time they went was right around when my warranty was up . i had a subaru dealer in okc do the work and they told me that the heads were fine and they were not cracked and didn't need any work but who knows? i will take to heads to a machine shop to have them checked out . so the new gasket from subaru are a lot better now . i don't want to have to do this ever again. unless anybody had a spare wrx or sti motor laying around anywhere i'd rather do an engine swap if u know wut i mean but thanks for all the help
Old 07-18-2005, 01:06 PM   #11
inurb
Member#: 53671
2001 GM6
The four door hater
I'm having the headgasket issue in my 01 RS at the moment. Hopefully subaru will cover it. If not I have an extended warranty. Only 50K on my RS too
EDIT: it was the air/fuel sensor and the mass air sensor. Ne headgasket issue on my 01 RS. just found out now.
inurb is offline   Reply With Quote
Guys with blown headgaskets, rate your driving style MaddMax Legacy Forum 16 06-16-2004 10:00 AM
used Subbies and blown headgaskets? dugrant153 Impreza Forum 6 03-15-2004 03:20 PM
Blown headgasket, cylinder (!!!!!!!) C-daleRidr Normally Aspirated Powertrain 25 01-30-2004 12:55 PM
Blown Headgasket seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 7 12-03-2003 12:10 PM
('93-'01) 13.3 @ 108 with a blown headgasket Tarmac Terror Impreza Forum 0 05-25-2001 10:27 PM
