Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 06-22-2005, 01:22 PM   #1
jwillis
Member#: 84742
2003 bugeye
Default aftermarket boost gauge
When installing and using the stock tubing, should I remove the restrictor that is in the hose in order to get accurate readings? The restrictor is located just after the T fitting. Thanks!
jwillis is offline   Reply With Quote
Old 06-22-2005, 03:48 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Keep the restrictor. It doesn't affect accuracy, its purpose is to dampen the gauge response to prevent the needle from oscillating or buzzing.
Old 06-22-2005, 10:49 PM   #3
jwillis
Member#: 84742
2003 bugeye
Thanks!!
Would installing aftermarket boost gauge void warranty? popnfresh Warranty Issues & SOA Problems 2 02-02-2005 05:25 PM
Factory or aftermarket boost gauge? wmailic Interior & Exterior Modification 3 07-14-2002 12:06 PM
Factory to aftermarket boost gauge raptor5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-08-2002 06:57 PM
Is my aftermarket boost gauge screwed up? sorny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-01-2002 05:57 PM
pic of your aftermarket boost gauge polobee69 Interior & Exterior Modification 4 10-21-2001 10:15 AM
