Old 06-22-2005, 08:15 PM   #1
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Default Oil pan crack on MY99'
Hi all,
Was doing an oil change today, and the frikkin weld in bung for the plug bolt cracked on one of the spot welds..!!
I guess flexing that area over time cause the bung to pull slightly and the force of breaking the bolt lose, caused a small (~1/4") crack round the edge of the weld..
So i need to get the pan out and have it welded, but i see that is easier said than done....
CAN i jack/wedge the engine enough to get the rear bolts out????? It doesn't look like it, but while i'm waitin for a/some replies, i'm gonna see what i can do...
Anyone, please, could to shed some light on me....
Thank you,
AaRoN
Old 06-22-2005, 08:22 PM   #2
jasper
Guest
Member#:
would it be cheaper to just get a new one?
Old 06-22-2005, 09:54 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You should be able to raise the engine enough to gain access to the oil pan bolts once you remove the two motor mount nuts and washers. You're probably going to want a 10mm swivel socket.
Don't forget to drain the oil first.
Good luck.
Tim Sanderson is offline   Reply With Quote
Crack on fuel injector. Need help ASAP! Finch1750 Newbies & FAQs 0 06-02-2010 07:14 PM
Cracked spot weld in oil pan - something to look for? Subie Gal Normally Aspirated Powertrain 20 11-29-2006 10:47 AM
Gunk on oil pan...Oil leak? Agkelos Service & Maintenance 9 07-07-2005 12:22 PM
Bugeyed WRX wagon oil pan work on STi? PA04STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 05-03-2005 01:05 AM
More WRX oil pan on a RS pics /w turbo oil return Revision Normally Aspirated with bolt-on Forced Induction Powertrain 0 09-08-2002 04:40 PM
