Old 06-23-2005, 11:59 AM   #1
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Default 100W bulbs in Hella 500's. OMFG!
So I've been driving around with a broken lens housing since someone backed into me last winter. Nice bouncy lights. Argh.
Anyway, last night I finally mounted a new housing, and put 100W bulbs into my driving pattern Hella 500's.
OMFG. It's almost as much of a difference as going from no aux lights to the 55W pair they come with. The only downsides are that:
1. I REALLY can't use them if there is any oncoming traffic less than a mile away.
2. The hot spot of the beams are *really* hot, which makes everything else seem dimmer, I think I'm going to need to add a pair of high-aimed fog pattern lamps to my bar to fill in.
Temperatures seem fine, the lenses were maybe 100-120 degrees after a 20 minute drive, and the backs of the housings were cool. Wiring was cool too.
I don't think I need to worry about nighttime moose any more. They need to worry about me, they'll burst into flames if the beam hits them square...
Chromer is offline   Reply With Quote
Old 06-23-2005, 01:12 PM   #2
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
i had 100w bulbs in my hellas beofre the yellow stars...be warned that 500's are proned to heat fractures, and you may end up with a huge crack down the lens...i know i have seen it on a couple of fog pattern 500's....dont think i have ever seen it on driving beams though..
ATX25RS is offline   Reply With Quote
Old 06-23-2005, 01:24 PM   #3
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Welcome to joys of auxiliary lighting.
As long as your moving, you shouldn't have to worry much about heat fractures, though when stopped, it's recommended that you turn them off since you have bulbs over 55w. Did you upgrade the wiring or just plug straight into the OEM foglamp wiring?
Old 06-23-2005, 06:26 PM   #4
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
The 500's are on a light bar with their own fused and relayed low-gauge wiring that runs straight off the battery. I haven't touched the (useless) stock fogs yet.
Old 06-23-2005, 06:52 PM   #5
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
be also warned that high wattage bulbs don't last as long as the lower wattage ones. I had some 160w ones that only lasted a couple of night time rallies.
RR
oh yeah, welcome to the world auxillary lighting. don't forget to post your set up in the "Ultimate Thread" for all to see.
here: http://forums.nasioc.com/forums/showthread.php?t=673117
Rapid_Roo is offline   Reply With Quote
Old 10-16-2006, 12:57 AM   #6
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
To bump an old thread.... have you run into any problems since, running this setup?
t3hWIT is offline   Reply With Quote
Yellow bulb in Hella ff1000 ShawnRS Electrical & Lighting 2 11-24-2004 09:36 PM
Moisture in Hella 500's Ahzlon Electrical & Lighting 2 04-07-2004 01:09 AM
Can you fit higher wattage bulbs in Hella 500's Rallyspec North West Impreza Club Forum -- NWIC 3 01-28-2002 04:46 PM
Don't use APC 100W Bulbs in your foglights! Scoob Mid West Subaru Owners Club Forum -- MWSOC 6 06-05-2001 02:33 PM
