Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-23-2005, 01:48 PM   #1
2003Baja
Member#: 52985
Default Baja losing oil?
I did an oil change over 1,000 miles ago, and at a gas station I went to check my oil. The dip stick had NO OIL on it! . I know subaru turboed models eat oil but I have an N/A
Was just wondering if anyone else had this problem. I did check my oil plug and filter and all was tight. There was some oil on the plug/pan but I'm pretty its sure it was from the last change. When I did the change I didnt find any washers in the bottom of the oil container like my moms sonata so I am pretty sure all is sealed......
EDIT: Ok, after adding THREE QUARTS of oil, all is restored. There seems to be a problem with the drain plug. (it was oily again) Oil is getting by it somehow, and I took out the plug just to see if it had a washer and it did. Well I'll see soon enough if the bottom the oil pan its slick again
2003Baja is offline   Reply With Quote
Old 06-23-2005, 07:05 PM   #2
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
try replacing the crush washer on the drain plug
Hawk296 is offline   Reply With Quote
Old 06-23-2005, 08:21 PM   #3
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
yes there is a washer, thats why its leaking.
Samirr76 is offline   Reply With Quote
Old 06-24-2005, 08:08 PM   #4
2003Baja
Member#: 52985
I'll go and order one ASAP. Talked to a local mechanic, he said the same thing. How much will it be u think it be?
Thanks!
Watch out for them pitbulls lol! (I stopped hard for one today and the ten 2x6x8's slid and pinned my hand against the steering wheel. Hurt my hand pretty good. Love how people at the home depto stopped/slowed down to watch how I loaded those big things into my baja )
Old 06-27-2005, 04:27 PM   #5
opimax
Member#: 85940
I did my first change on my 05 N/A Sunday at 2k it was down a quart. I will be watching...
Mark
opimax is offline   Reply With Quote
Old 06-27-2005, 06:22 PM   #6
Samirr76
Member#: 4835
2003 Baja 5MT
We go up to 5k miles between oil changes and havent burnt any oil, not a drop.
Old 06-27-2005, 09:13 PM   #7
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
You can use the washer up to two times, no more....
BajaT05 is offline   Reply With Quote
Old 06-27-2005, 09:26 PM   #8
nurseman
Member#: 85518
Thumbs up oil loss
i did my first oil change on my 05 baja turbo at 3K miles. i noted that i had to put 5 qts in to fill it even though the manual states a 4.1 capcity. but i would say it ate atleast a quart in that 3k miles. as well my car doesnt leak oil and on my 02 impreza rs with 110k miles i never changed the crush washer and never burn leaked oil ever. the washer is 89cents at the dealer
nurseman is offline   Reply With Quote
Old 06-27-2005, 09:55 PM   #9
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Alot of times if you go to the dealer and say you have a filter already but forgot the washer last time they will just GIVE it to you.
Its nicer to them though if you buy an extra filter with 2 washers when you are there (one for now and one to use with that new filter)
Flowmastered87GL is offline   Reply With Quote
Old 06-29-2005, 03:18 PM   #10
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
Is the Factory filter better than a K&N oil filter?
Did up/downpipe yesterday, now losing oil from turbo vicinity. Jard Factory 2.0L Turbo Powertrain 12 08-16-2004 12:47 PM
Losing Oil EJ205rulezall Service & Maintenance 4 06-06-2004 11:15 PM
Losing oil? redoktober_99 Service & Maintenance 4 07-31-2002 04:57 PM
Losing Oil HudsoN456 Normally Aspirated Powertrain 33 12-10-2001 02:02 AM
OT: Causes for an engine to lose oil pressure under loads? AaronB Technical Forum Archive 6 06-06-2000 10:24 PM
Message Board Statistics All times are GMT -4. The time now is 05:54 AM.
