Old 06-23-2005, 03:22 PM   #1
CrazyMike13
Member#: 44615
2002 WRX Wagon
1st Guru Point EvAr!
Default Problems with my catless exhaust (CEL Related) HELP!
I've had a catless exhaust for over 6 months now and I was used to the CEL codes I was getting. Well, I finally got an MIL Eliminator that I thought would take care of the codes. I thought wrong.
I'm getting a misfire on ALL 4 Cylinders and a problem with the front 02 Sensor. The CEL pops up ONLY when i'm at idle.
I have COBB CAI, Borla Headers, Custom track pipe, and an Apexi N1 exhaust along with a lightened flywheel.
Does anybody know what could be causing these cylinder misfires and what I can do about them?
Any help is appreciated.
Thanks!
-CM!3
CrazyMike13 is offline   Reply With Quote
Old 06-23-2005, 05:33 PM   #2
tmeh
Member#: 30800
2000 .7 RS
maybe the sensor has finally bit it?
i had front and rear 02 fail codes with my brullen equal+high flo cat+tanabe race pipe and changed the front 02 sensor, then next time the MIL came it was just the rear fail.
if that could go bad enough to cause misfire i'll let somebody else diagnose.
front 02 is upwards from the cat right, so catless or not shouldn't affect it alot...
maybe the wiring for the MIL eliminator is causing more problems
tmeh is offline   Reply With Quote
Old 06-23-2005, 06:38 PM   #3
CrazyMike13
Member#: 44615
2002 WRX Wagon
Well, I was getting misfires before the MIL so, i'm sure that's not what's CAUSING it, but if the front 02 is failing and CAUSING the misfires, then that would definitely explain it.
Does anybody know if the 02 sensor can cause misfires?
-CM!3
Old 06-23-2005, 06:42 PM   #4
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
I am not fully sure, but I would not be suprised since the front O2 sensor controls the A/F raito, and if it's FUBARDed, it would create the wrong ratio for the engine to run on. Then that can cause misfiring, or "limp mode"
impr25rs is offline   Reply With Quote
Old 06-23-2005, 07:19 PM   #5
karl_hungus
Member#: 7507
2002 WRX Wagon
I had the same problem and I have similar setup to yours but Brullen headers instead of Borla.
With those mods your car runs very rich so the 02 sensors will fail prematurely. I now make a point of replacing my front 02 sensor almost annually, might be overkill but I am a bit paranoid. I've replaced the front 02 twice now and I have not seen any misfire or lean condition codes since.
karl_hungus is offline   Reply With Quote
Old 06-23-2005, 08:39 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
How many miles on your car? Have you ever replaced the front air/fuel sensor? Have you ever replaced the rear o2 sensor? How are your plugs? how about your fuel filter?
I had the p0420 intermittently from 70k till 120k miles. I changed both my sensors and all is good.
I can't help with the misfire code, sorry.
Tim Sanderson is offline   Reply With Quote
Old 06-23-2005, 11:00 PM   #7
CrazyMike13
Member#: 44615
2002 WRX Wagon
70K+ miles, never replaced the front air/fuel sensor, plugs are new and new fuel filter.
So it looks like i need to replace the front 02 sensor?
Thanks for all the help so far!
-CM!3
Old 06-24-2005, 02:12 AM   #8
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
mingnight pearl black
cats suck huh
tsubaru02 is offline   Reply With Quote
Old 06-27-2005, 01:24 AM   #9
CrazyMike13
Member#: 44615
2002 WRX Wagon
BUMP cause i'm about to purchase an 02 sensor and not sure if that's what I need!
-CM!3
Old 06-28-2005, 01:08 AM   #10
The Anti Riced
Member#: 89736
1986 VW GTi 16V
alpine white
if i understood correctly, you aren't running a catalytic converter? why?
do you have any idea what you are doing to our breathing air/ environment?
The Anti Riced is offline   Reply With Quote
Old 06-28-2005, 04:31 AM   #11
Nicklbrso
Member#: 44887
00 GC6
This has nothing to do with what he's asking. Leave your own personal beliefs out of this.
Mike,
I would replace the front O2 sensor if it has never been changed w/ 70K miles.
Nicklbrso is offline   Reply With Quote
Old 06-28-2005, 09:26 AM   #12
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
I am not going to read the whole thread... so let me post...
My car did this same thing when I replaced the clogged up stock cat with a RT high flow. Within a few days my front O2 took a dump and so much gas was being dumped into the cylinders, the spark plugs simply could not ignite the mixture. I replaced the front O2 sensor (which can be done without getting under the car) and everything is fine... just back to the same old 0420 CEL...
Texas25RS is offline   Reply With Quote
Problems with my wrx stephentodd Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-02-2010 08:53 PM
installing my catless dp tomorrow need help with cel Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-26-2009 09:49 PM
Need some help with a problem with my knee StuBeck Off-Topic 65 01-12-2006 12:24 PM
i got a problem with my 04 sti can anyone help? gotmilk2001 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-02-2005 10:33 AM
Slight problem with my Turbo timer - help! djerickd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-26-2001 12:06 PM
