Old 06-23-2005, 04:10 PM   #1
popnfresh
Member#: 72832
Default How durable is an EGT tap?
Im wondering what the chances are of an exhaust leak from where it is tapped, or how durable the plug would be in long term use?
thanks guys.
popnfresh is offline   Reply With Quote
Old 06-23-2005, 09:27 PM   #2
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Don't worry about the threaded connection. If you use the proper drill and don't screw up the tapping of the hole you will be alright.
As far as the probe goes, I'm not sure what to tell you. There are different types of probes - shielded & unshielded. AFAIK, the shielded probes will last longer but have a slower response time. Maybe someone else can chime in with actual probe life examples.
jac04 is offline   Reply With Quote
Subaru Interior - How durable is it? joeyb7 Interior & Exterior Modification 9 06-27-2005 11:05 AM
Is an EGT gauge necessary?.... TastyTurbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-18-2003 08:27 PM
How long should an EGT probe last? Eskram Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-04-2003 10:43 PM
How durable is aluminzed steel? Robmat Newbies & FAQs 0 04-30-2001 06:44 PM
