Old 06-23-2005, 04:12 PM   #1
KnightWRX
Member#: 41664
black
Default So I got Sylvania silver stars put in......
So, I got the Sylvania Silver Stars a few days ago. I was really looking for bulbs that from a distance look that "purplish/weird color" but once you get closer they just look pure white.
First impressions of the bulbs are that they are in fact a pure white color and yes it does light up way more than my stockers did, but I cant exactly park my car with the lights on......run 100 yards down the street just to see if the color shifts from a distance.
So my questions are these.....
1) Do real HID's have a color change?
and
2) Does anyone have Sylvanias "cool blue" bulbs and would I be able to tell they are a blueish color when driving. How is the visibility compared with the silver stars.
Michael
KnightWRX is offline   Reply With Quote
Old 06-23-2005, 04:17 PM   #2
popnfresh
Member#: 72832
hids will be bluish until they warm up, then they will be white or white/blue depending on what temperature they run at (4300k 6000k)
i think you are talking about the look that cars like audis have, from far away they look to be purple, blue and white all at the same time. i think this has more to do with the way the projector is made, and not necesarily the HID itself.
popnfresh is offline   Reply With Quote
Old 06-23-2005, 05:26 PM   #3
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
Exactly... that color shift you are looking for has to be coming out of a projector lens type setup. Even an HID retrofit in a reflector housing will look the same color from every angle, it's the projector cutoff that makes it change color.
I had the Cool Blues, didn't like them... they lit up dimmer than the Silverstars and IMO was just another blue-tinted superwhite headlight bulb.
Uncle Ben is offline   Reply With Quote
Old 06-23-2005, 05:36 PM   #4
KnightWRX
Member#: 41664
black
cool...well thanks guys. Yeah the Audi's and such are the cars that Im thinking about. And also, thanks for the heads up on the cool blues. So they are not "blue" light at all then huh?
Michael
Old 06-23-2005, 06:09 PM   #5
Xymox
Member#: 410
So you guys running Silver Stars, are you overly pleased compared to the standard bulbs? Or is this just slightly better (albeit more expensive) than the standard bulbs?
Xymox is offline   Reply With Quote
Old 06-23-2005, 11:55 PM   #6
Uncle Ben
Member#: 28628
2003 WRX Sedan
Its just slightly better, I don`t see honestly how a standard 55w halogen bulb can be THAT much better no matter how well they engineer it. That said, I think the Silverstars are worth the extra few dollars though, the bright white color is nice.
Xymox, are you the same one that used to frequent VWVortex?
Old 06-24-2005, 12:33 AM   #7
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
It's marginally better, as in- not really worth it. the coating on sylvania silverstars is purplish-blue, but it's mainly there to filter out the yellowish light that makes regular halogens seem not white.
they're nice, and they're engineered well, but they're not worth the extra money IMO.
the effects really fade after you've been looking at them for a while. when i put my stock bulbs back in, i was expecting much yellower output... and it's such a minute difference i don't think it's worth it.
if you disagree with me, look at your light output(from the driver's seat) with silverstars first, then switch back to regular halogen. everyone judges it from the other way around, and i think the results of the visual test are skewed.
that's coming from me, mr. "wow i just put them in and they're so much whiter and brighter"
Handsdown is offline   Reply With Quote
Old 06-24-2005, 02:53 AM   #8
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Osram silverstars are more effective, they're not coated so they have a brighter look.
eltrouble is offline   Reply With Quote
Old 06-24-2005, 08:18 AM   #9
Xymox
Member#: 410
Thanks for the "real life results" fellas. And yes, Uncle Ben, I'm Xymox from VWVortex (a long long time ago)
Old 06-24-2005, 01:54 PM   #10
Uncle Ben
Member#: 28628
2003 WRX Sedan
Damn, that makes me feel old :P
Old 06-25-2005, 06:24 PM   #11
Eleazar
Member#: 68773
1993 Saturn
GOLDEN
but do they make the osrame silverstars in 9007?
Eleazar is offline   Reply With Quote
Old 06-25-2005, 06:33 PM   #12
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
they used to, but they stopped making them so even the importers that used to have them are having trouble finding them, IIRC.
Old 06-25-2005, 06:42 PM   #13
KnightWRX
Member#: 41664
black
Default highbeams mean.......only 1 light?? (shrug) 02 WRX
I just put in Silverstars this past week and they work just fine.....on both sides. However, last night I flipped on the highbeams on the way home and only the passenger side lights up. Once you flip them back to low, the drivers side turns back on.???
10 minutes later.....all of a sudden they work ok again. Then later in the evening back to the same 1 light thing happening.
Anyone have any suggestions on what the heck is the problem? If the wires were loose...or the bulb was loose wouldnt the low beams be cutting in and out as well on the drivers side.?
Michael
Old 06-26-2005, 12:26 AM   #14
surferdude166
Member#: 54970
2005 Xterra
search for daniel stern lighting that's where I got my osrams and I am sure he had a list of the bulbs he could get for you
surferdude166 is offline   Reply With Quote
Old 06-26-2005, 01:57 AM   #15
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
why dont you just get some morrettes and hids...solve all the problems
ATX25RS is offline   Reply With Quote
Old 06-26-2005, 02:10 AM   #16
markadopolus
Member#: 69586
Teh silverstars IMO are a little better, But they are worse than the stockers in rain. The rain drops just soak up all the light. Thats why I also got yellow fog lights. I myself and others have noticed that one of your silverstars will burn out very fast. I disconnected my DRL's to make them last longer.
markadopolus is offline   Reply With Quote
Old 06-26-2005, 03:49 AM   #17
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
blah blah blah
Michael
i'm assuming you have regular bugeye headlights, if that's so, your bulbs are 9007
which are dual filament, one for low and one for high.
so maybe the driver's side highbeam filament is burnt out?
or partially busted?
i don't know.
Old 06-28-2005, 02:05 PM   #18
NF2
Member#: 51443
in search of
ave. P in PA
i had silverstars for a while ,but they burnt out a lot quicker than stock bulbs. i was extra careful installing them, making sure not to touch anything, but they just dont last as long. i switched back to stock after going thru 3 sets.
NF2 is offline   Reply With Quote
Old 06-28-2005, 10:01 PM   #19
eyehate
Member#: 10223
i have them in my fogs and they are much better than the stick lights imho!
eyehate is offline   Reply With Quote
Old 06-29-2005, 01:04 AM   #20
rabbitnutz
Member#: 51940
only bulbs i can recomend are PIAA super plasma GT-X's. they have a ultra bright white/purple ish low beam, and super freaking pure white bright ass high beam. i love em.
rabbitnutz is offline   Reply With Quote
Old 06-29-2005, 03:04 PM   #21
ludecrous
Member#: 19376
2003 03 WRX Wagon
Sylvanias "cool blue" bulbs are complete crap, don't waste your money, light output low.
ludecrous is offline   Reply With Quote
Old 06-29-2005, 04:35 PM   #22
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
there nice under normal driving conditions. they suck at what they are supposed to be used for. i had a fog set and one bulb blew within 2 months.
doubledribble is offline   Reply With Quote
Old 06-30-2005, 12:17 PM   #23
MtnGoat
Member#: 86243
2001 2.5RS brp
07 FXT Sports ugm
Thumbs up PIAA super plasma
I have to agree
I have the PIAA Super Plasma also and
if the bluish look iswhat you are looking for
than Piaa is a good choice. They look great from
a distance and put off a nice lavender/blue color.
And the high beam IS a Insane bright white
cost is around 80 bucks. The PIAA site has good info.
Those cool blue lights are a waste of money
MtnGoat is offline   Reply With Quote
Old 06-30-2005, 04:22 PM   #24
MtnGoat
Member#: 86243
2001 2.5RS brp
07 FXT Sports ugm
Default PIAA super plama
Left side PIAA right side stock
[IMG][/IMG]
[img=http://img15.imageshack.us/img15/4559/piaa26ps.th.jpg]
You can sorta tell
Old 06-30-2005, 09:19 PM   #25
Blind Moose
Member#: 90037
2008 WRX
I had the Sylvania Silver Stars in my 00' Outback and they lasted about 3 months before burning out. They were installed as per the instructions. I noticed the light was a bit whiter, but they didn't seem any brighter. I put the standard bulb back in and can't tell much of a difference between them.
Blind Moose is offline   Reply With Quote
Sylvania Silver Stars -- Ehh... dowroa Car Part Reviews 1 08-19-2003 11:49 AM
Sylvania Silver Stars Warmwaffles Interior & Exterior Modification 66 12-30-2002 04:39 AM
Are Sylvania Silver Star any better than the PIAA SuperWhite? Leonardo Interior & Exterior Modification 64 11-09-2002 11:28 PM
Sylvania Silver star Halogens?? Jfrankon Interior & Exterior Modification 20 09-13-2002 11:14 AM
Message Board Statistics All times are GMT -4. The time now is 05:45 PM.
