Old 06-23-2005, 05:35 PM   #1
lilrex85
Member#: 67430
Default hey, i gotta question bout nitrous..
hey guys i'm kinda new here, haven't posted many threads or anything. i have a turbo xs turbo back exhaust, a dual stage boost controller, and an apc stage 1 clutch kit.. i dont have too much money to spend on the car between the wife an spendin money an everything. i want some more power, an i need to do some audio work in the futre. i was thinking about getting a nitrous kit, but i don't know if i should get a wet or dry one, and if i'll need anything else to buy to be on the safe side.. any suggstions will be greatly appreciated. thank you.
lilrex85 is offline   Reply With Quote
Old 06-23-2005, 06:00 PM   #2
black05wrx23
Member#: 68642
05 wrx
black
well you dont have much money to spend but u want nitrous? no offense in the end youll be spending more money on a new motor look for a different route. Now if you want to do it the right way get engine management FIRST do the basic fuel upgrades and have a PROFESSIONAL install it then I guess get a map tuned for it. I dont think there is much else to be on the safe side. Personally I would get an exhaust first. If its possible get rid of the cats
black05wrx23 is offline   Reply With Quote
Old 06-23-2005, 06:18 PM   #3
-Kevlar-
Member#: 82378
you could probably get like a cobb AP or something for about the same price as nitrous and its a lot safer and almost the same power to be gained (w/ up and downpipes)
-Kevlar- is offline   Reply With Quote
Old 06-23-2005, 07:43 PM   #4
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
personally I'm not a great fan of NOS, I think the money is better spent elsewhere. If you want to shoot off huge amounts of NOS in your car you'll usually end up running lean, plus all that cold air being fired into the cylinders ain't great for the engines. But anyways, if you want modifications to make the car run properly...
I highly highly recommend you get some form of engine management. The turboback is a great modification for horsepower, but without EM you might get some screwy OL/CL issues. Boost controllers are also notorious for killing engines without a good professional tune. My suggestion would be to find a local tuner who has a good reputation with engine tuning, and knows how to work with ECUTEK, get it professionally tuned.
eltrouble is offline   Reply With Quote
Old 06-24-2005, 12:06 AM   #5
lilrex85
Member#: 67430
i'm not exactly sure as to what ecutek is... is that pretty much the same as turbo xs' engine management?? cuz that runs for about $900, then to get it tuned runs about another $300-$400. i only increased the boost on my controller 3 psi,and i emailed someone from cobb tuning and they said their access port isn't compatible with the boost controller, and if i get rid of the boost controller an buy the ap, then i'm still going to have around the same power as now... can't spend $1300, its not in the funds
Old 06-24-2005, 12:30 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
*boom*
Old 06-24-2005, 12:37 AM   #7
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
get a utec
adeliciouspizza is offline   Reply With Quote
Old 06-24-2005, 01:01 AM   #8
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
*boom*
Uncle Scotty said it best. That's pretty much the sound you're going to hear if you keep boosting above stock psi without EM.
get a utec
yes well, you can get a utec as well, or an ECUTEK, it all depends on your needs and what you plan to do with the car.
ECUTEK is basically a license, it allows professional tuners to use ECUTEK to tune your car. Costs around $500, allow $300-$400 for tuning. Of course it's a professional tune, so if they know what they're doing, they'll adjust the ECU so that it will run as efficiently as it can, as well as drawing out the most power from your modifications. Unfortunately you cannot tune ECUTEK yourself if you wanted to.
TurboXS Utec is something you install into your ECU. You can use a laptop to tune it yourself, or get a professional to tune it for you. There's also this nifty device you can purchase that will switch between the 'low boost' and 'high boost' mode that makes it popular. Set it to low boost on the daily drive to save gas, flick that switch to 'high boost' at the racetracks and you're ready to go.
Both have their pros and cons, it's up to you to decide which is better. UTEC has the most flexibility because it allows the owner or the professional tuner to do the work, and you can switch between ECU settings. Of course this is the most expensive option as well, costing a total of $1200-$1300 for the cost of UTEC and tuning. Of course if you know how to tune the car yourself, UTEC would be your choice. ECUTEK is cheaper, and still allows a professional to tune your car, in case you're the 'hands off' kind of guy. Of course if you constantly go engine modifications, you'll need to pay constant money to get it constantly tuned.
My personal preference is ECUTEK.
You seriously need engine management, it's now a necessary thing since you increased the boost. You should set the boost at its stock settings and keep it there until you do get the funds for EM. Tuners everywhere have horror stories about how boost controllers have killed engines, and then the owners of the car blame the car for being 'poorly made'. The increase in boost increases the amount of air flowing into your car, which is great, unfortunately the fuel injectors are still shooting the same amount of fuel they normally would. This results in your engine running lean, which is death to any engine, ESPECIALLY a turbocharged one. Even running 1 psi over the stock limits without EM will eventually lead to a killed motor.
Well, I hope by now that you plan on getting EM, I would hate to see you prematurely break the car because of that nasty boost controller. With EM a tuner can adjust the ECU to work with the boost controller, so that way it will work for you.
Old 06-24-2005, 01:29 AM   #9
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
mingnight pearl black
i love the n2o becareful or you might have to get a ver7 like me
tsubaru02 is offline   Reply With Quote
Old 06-24-2005, 01:37 AM   #10
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
NO2...1 nitrogen 2 oxygen atoms.
Old 06-24-2005, 01:57 AM   #11
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Then you better pull that stuff off your car. When it goes, you will be spending it, or walking a lot.
bofh is offline   Reply With Quote
Old 06-24-2005, 02:01 AM   #12
Roy Lin
Member#: 38890
Not worth it unless you have tons of money lying around to fix your car. If you "aint" paul walker dawg, i suggest you get long term power modifications like engine management, well thought out stage upgrades, etc. etc.
Accessport is my next choice in upgrade, it's affordable and very flexible. UTEC is basically a programmable unichip and it's almost universal that normal folk can't program it right. When Worldone had a proffesional tuner come to the NW he noted that ~90% of the amateur tunes were complete junk.
:0
Roy Lin is offline   Reply With Quote
Old 06-24-2005, 02:07 AM   #13
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
:0
The off-the-shelf maps aren't considered as safe as a professional tune, and you probably won't net as much power from the engine as you could. AP ProTuner is an excellent choice....however the cost of AP+ProTuner is $1,000, you might as WELL get the UTEC if you're spending that much.
And yes I agree, the vast majority of amateurs don't know how to properly tune, WHICH is why I'm going to let my local (and highly respected and trustworthy) tuner do the work. Plus the guy who's going to tune it works for a large aftermarket company that works very closely with Subaru...so yay.
Old 06-24-2005, 02:19 AM   #14
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
sorry about that
Old 06-24-2005, 09:03 AM   #15
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
that's pretty funny. no doubt true.
when i take a peek at professional tunes, ~50% of them are complete junk, so i agree.
Old 06-24-2005, 09:25 AM   #16
wrxedya
Member#: 45295
blue bugeye wrx
with another gear
amateurs dont use nitrous........
andrew
wrxedya is offline   Reply With Quote
Hey guys, gotta question! tapout228 Newbies & FAQs 3 05-03-2008 01:31 PM
Questions bout unichip & boost controllers Akord Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-12-2001 10:42 PM
hey i gotta get rid of this thing please? doripreza Southern California Impreza Club Forum -- SCIC 9 05-26-2001 02:07 AM
Yet another question bout NOS: The mathematics..N E one KNow? Syms General Forum Archive 1 10-25-2000 05:30 AM
Question bout keyless entry MadMax Technical Forum Archive 6 06-02-2000 12:36 AM
