Old 06-23-2005, 06:15 PM   #1
lag
Member#: 34631
to live in fear
Default Driveline vibration between 68-72mph
It's petty bad I'd say and very much annoying. I had the car on a lift today changing oil and misc. and checked the wheels and got to the half-shafts and the two fronts I can wiggle about 2-3mm grabing the shaft in the middle. I worked my way down to the stub sticking out of the tranny and I can wiggle it there as well. Is this normal (I suspect not) but is this tranny rebuild time or is my vibration coming from some where else?
lag is online now   Reply With Quote
Old 06-24-2005, 10:29 AM   #2
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Have you tried balancing the tires and wheels?
I am not sure how much play the CV are supposed to have so I can't help there. I have had a few harmonic type vibrations at certain speeds and have always solved it with balancing.
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 06-24-2005, 11:58 AM   #3
MitchGT
Member#: 73684
2012 4Runner
Peace,
Greg
+1...
MitchGT is online now   Reply With Quote
Old 06-24-2005, 12:00 PM   #4
lag
Member#: 34631
to live in fear
yepper, no luck.
Old 06-24-2005, 12:08 PM   #5
Dobes
Member#: 164
2008 Exige S240
There usually is a fair amount of slop in the half shafts. On my RS I can rotate the half shafts a bit back and forth before the trans starts rotating. I think your wheels and/or tires are unbalanced.
JD
Dobes is offline   Reply With Quote
Old 06-24-2005, 12:24 PM   #6
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
+3 on the balencing. I got a new set of tires and then I had a wicked shimmy at 60-65 mph. I brought it back the next day and they guys said "ya I guess out balencer was out of wack yesterday, we have had 5 other people back today for the same deal"
bhall is offline   Reply With Quote
Old 06-24-2005, 02:40 PM   #7
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
generally if you can drive into/out of a vibration in the steering, it's going to be balancing.
It could also be the tread itself - I had a problem a few years back similar to this, I swapped the wheels front to rear, problem gone.
If you can feel vibration thru the transmission tunnel, it could be a worn tranny mount.
Huffer is offline   Reply With Quote
Old 06-24-2005, 02:48 PM   #8
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
I'd say balancing too. I've got blown shocks up front, and I am thinking it makes the problem more pronounced. So if you have older/worn out shocks, even the smallest balance problem could seem bigger.
On my car, between 60mph and 75mph I had a bad vibration (like tire going flat feeling).Tires were swapped around and the problem is gone since the slightly out of balance tire is under a good shock.
Another good thing to check is if you've had the wheel off recently, make sure all the bolts are torqued down correctly.
Plays_With_toys is offline   Reply With Quote
Old 06-24-2005, 03:00 PM   #9
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
also if you got dem maD TytE spinna hub caps yo one could be spinnin out of wack yo.
once again i got nothing...
Old 06-24-2005, 03:29 PM   #10
lag
Member#: 34631
to live in fear
lol,
well, I guess I'm going to rotate and balance again. I'm going to take it in for an alinement as well. Hopfully one of these things will cure it.
Old 06-25-2005, 12:00 PM   #11
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
One other thing to check (I have had this as well) is a dragging front caliper.
Get on a highway and run the speed up for 5-10 minutes. Carefully pull to the shoulder with minimum braking. Get out and check the center of each wheel. You may find one that is warmer then the others (by a noticeable amount). If so, get home and pull it apart. I had a piston sticking and it was dragging the brake.
My gas mileage was also low when it happened.
A rebuilt calpier was ~$60 from a local parts place.
Intense Rear End Driveline Vibration redbishop Transmission (AT/MT) & Driveline 18 11-26-2007 03:28 PM
Driveline Vibration balrog Transmission (AT/MT) & Driveline 5 10-01-2007 09:47 AM
Heavy driveline vibration above 65mph after tranny swap Geek Guy Subaru Conversions 5 11-27-2006 09:55 AM
Severe occasional driveline vibration jamesf Transmission (AT/MT) & Driveline 1 09-15-2006 03:55 PM
Warped front hub/rotor driveline vibration Aprilia Jon Brakes, Steering & Suspension 4 09-27-2002 01:12 PM
